Help, How to hook up 4 batteries
  • Snowride
    • 297
    Can someone here help me in determining the configuration I would need to plug an additional set into my existing setup to run 4 batteries as opposed to 2. I would like to simply add an adapter to each side but need to know how to wire it. I have the wire and connectors in hand and am very capable with a soldering gun. I am presently running 2, 3S batteries in parallel to give me 6S. I need to remain 6S and the same voltage after connecting so I assume I need to hook the additional ones up in series to each existing battery? Is this correct?
    I found these adapters pre made with EC5 connectors. Which one if any of these would work for what I want to do? I do have EC5 connectors on my setup already.
    PRC Home - iCharger, ISDT, FPV Drones, iFlight, RadioMaster - Battery Chargers - Mean Well & Iota Power Supplies - ProgressiveRC
  • Rcforever27
    • 240
    You have to parallel the batteries... Parallel keeps the voltage the same , but doubles the capacity. Series doubles the voltage and keeps the capacity of one battery. I'm gonna be running a series/parallel setup. 22.2 volts but 16000 mah.... Series to get 22.2 volts, and parallel to get 16000 mah.... Good luck!
    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
    • Rcforever27
      • 240
      Also read my other post titled,"4lipos?"....
        • 9481
        http://www.progressiverc.com/index.p...5-adapter.html
        running two 3s packs to get 6s is called series
        if you ran two 3s packs in prallel you would still have 3s
        so you could run two 3s packs in parallel x 2 ( 3s )
        then wire those in series to get 6s
        or run two 3s packs in series x2 ( 6s )
        then wire those two setups in parallel to keep 6s but double the Mah
        • dag-nabit
          • Feb 2011
          • 775
          Yes, that first connector you linked to (parallel) will work. You will need two of them.
          The only possible problem is they are 12 gauge wire, which might be fine, but with high amp draws 10 gauge would be better.
          Here are some I soldered up using 10 gauge wire.
          Here is a parallel into series connection. My series connector is a bit too long, but gives you the idea.
          Hope this helps
          Kevin
            • 9481
            when your running parallel like this with the amp draw we are seeing 12G will be fine
              • 9481
              Snow, this is how I do things
              and much less resistance that what was posted and to me much easier to put together
                • 9481
                With bullet connectors this is how I do series
                these are 2s packs so they are now wired in two sets of 4s
                  • 9481
                  My simple parallel connectors, same thing for 3s packs
                  and you can see how they connect the two sets of 4s packs in parallel
                  and to the speedo
                  and as we can see a clean simple setup with less resistance
                  • Snowride
                    • 297
                    Wow, thanks for all the pics and info, really appreciated. I have 4 nano tech 6.0 3s and also 4 turnigy 5.8 3S which I want to use together to run my boat. That should give me 2 runs of 20+ minutes before looking for the charger. With all this info I will easily be able to solder up my own. Thanks again.
                      • 9481
                      Glad we cold help Snow
