21/40 stinger drive unit...
  • Rcforever27
    • 240
    So I had this drive that I ordered from ose and never put it on... Going to put it on my Spartan and my question is after it's all on, should I leave it level with the hull or have it pitched up slightly? Now I'm gonna be running 4 3s lipos i'n series parallel and will be able to use 2 3s lipos by just unplugging the harness me and my father are making.... Thanks i'n advance fir any info!
    Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
  • dag-nabit
    • Feb 2011
    • 775
    I'd start with level, then play around with a bit of positive or negative pitch to see what works best and gives you the results you are looking for.
    Kevin
    • Rcforever27
      • 240
      Ok sounds good that's what I thought I was gonna hear... That's good tho . Just wasn't sure if there was a rule of thumb for adjusting those ... Trial & error I guess... Lol thanks!
        • 9481
        it's the best way!
        if you start out more neutral and take things easy you should be just fine then start making very small adjustments tell you find that sweet spot
