New steering servo needed
  • trevorla
    • 15
    Anyone upgrade their steering servo? I think my traxxas 2056 is shot.Took it apart it smells funny and was warm to the touch.It appears to be not as waterproof as advertised...
  • wilsta67
    • Feb 2011
    • 203
    any std size servo will fit.
      But why put just any servo in the boat? A boat that size needs a high torque servo to keep good control at high speeds. The force on the rudder can overwhelm a standard servo, causing funky control in corners, hooking, etc.
      A servo with at least 80 oz-in at the receiver voltage supplied is a minimum IMO. The first below should work if you have 6 volts to the receiver. If you only have 4.8 volts to the receiver, then use the second one, which is the better choice either way.
      Welcome to ServoCity where you can get the parts you need to bring your ideas to life! From servos to switches, from actuators to Actobotics, we work hard to bring you the best components backed by unparalleled technical support
        • 9481
        Hitec HS-645MG is good and cheap!
        http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXUZ89
        • wilsta67
          • Feb 2011
          • 203
          thats a std size servo lol
          a micro servo will be to small and a 1/4 scale to big 0_o
            • 9481
            Uhhhh
            fluid and I both posted std size
            • roadrashracing
              • 1630
              Mine went after 4 packs, I send it in and I'm getting a new one
                • 9481
                get the HS645MG you will like it so much more
