Hi what gps do you guys recommend tht won't break the bank?
Gps???
Gps???
Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....Tags: None
Ok thanks! I'll look into it!Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
when you pop the hatch, it is reading realtime so the speed will say zero. But after pushing a bunch of buttons you can get last run. Not like what you see here where they pop the hatch and it shows max speed instantaneously but it does a lot of other crap that I don't need or know how to use. If I remember, it was 80 bucks shipped new.
Ok thanks alot!Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
If you are considering a Watts Up Meter and a GPS. Have a look at The Eagle Tree System with GPS expander. The GPS module only weighs a few oz.
It will cost more than those other two items, but gives you more data and lots of flexibility to add temp sensors, etc.
Can also be used on your cars.
The eagle tree needs to downloaded onto a computer to read the data, or you can buy a little data reader card for viewing readings in the field.
Look at the 150 amp model with wire leads so you can use your own connectors.
Kevin
Ok I'll check it out . Thanks!Scott Spartan#1: castle hydra ice 240 castle 2200 Prather 220 turnigy 5.0 45c lipos with max amps water pump... Spartan#2: leopard 1800, octura 440 ,traxxas 8400 mah 25c lipos.....updated deeper hull....
