Leopard 3674 1700KV. This on 6S? Would this be a good choice on stock ESC. Max amps sayd 72 amps stock is rated at 80 i think? Would this make Spartan hit 50mph or more?
Motor Thought
I think that motor would work with stock ESC. Only 100kv more than OEM motor, but it is a more efficient 4 pole motor.
The question is, how reliable is the stock ESC with any motor???
FYI
The 1700kv motor is what I will be running, but with T180 ESC.
Kevin
your probably see around the same speed with that Leopard as the original motor but more reliable & you might have to prop down slightly because of the increase in rpm. Nearly 38000 rpm will be quite high for a mono hull of that size. Martin.
I will be, in both Spartans, if it ever warms up here enough to thaw the lake.Originally posted by Shaun78 View PostKevin, u r running that motor? 3674 1700KV?
I have Tacon 3674 1700kv motors. I ordered Leopards, but was shipped Tacons. The research I have done suggests they are the same motor, just re-badged.
I'm hoping they prove out to be reliable.
I also have a couple other motors I can play with if these don't give me the result I'm looking for, but I'm confident they will. I may play around for some top end speed, but mostly my daughter and I just chase each other around the lake, so if I can run 47 - 53 mph with good control and reliability, I will be a happy camper.
Here is my current setup, both trays are the same configuration.
T180 ESC
Tacon 3674 1700kv
Aluminum Water Jacket
Spektrum MR3000 rx
Upgraded Collet
Running 6S
I could use my upgraded spartan ALum. jacket. What prop r u thinking? Stock? it should be able to hit 50mph as its a better,more powerful design than the Stock setup. Hmmmm I wonder if stock ESC will work, I have a new seaking on its way but if i dont need it. Probably better off using it thoughGenesis (Bosncali Geico Beater) Leopard 4082 1500KV
(63.7 MPH) Traxxas Spartan (same setup)
Your call on the ESC, I choose to switch mine out without ever powering it up. I figure if it torches and takes a set of batteries with it, it isn't worth the chance. More importantly, I don't want the ESC to flare up on my daughters boat while she is hooking up batteries or something.Originally posted by Shaun78 View PostI could use my upgraded spartan ALum. jacket. What prop r u thinking? Stock? it should be able to hit 50mph as its a better,more powerful design than the Stock setup. Hmmmm I wonder if stock ESC will work, I have a new seaking on its way but if i dont need it. Probably better off using it though
You might have a good one, and not have any issues.
For props I'm not sure, won't be stock though. I have an assortment to try and will settle on the one that gives me good speed, good hole shot, and stable ride.
I agree that it should be possible to hit 50 with the stock prop on this setup in light of the fact a couple (few) guys have managed 50 on the stock setup.
Maybe a Prather 215 or 220, or I have a couple 3 blades I want to try. Will depend on amp draw with this set up, as well as performance.
Kevin
