Stock strut and grease leaking fix
  • JPriami
    N4FOX
    • 1711
    Putting another idea i had to the test today. When you run the Spartan with the stock strut and flex cable and grease it. Just about all the grease comes off in the first run. It gets pushed and sucked out of the stuffing tube. Then it's all over the front of the strut where it meets the hull. Between the gap of the hull and strut. So I figured to help keep the grease in the system you can place a rubber grommet in the gap to help seal it.
    Will be trying it out later today.
  • martin
    • 2881
    Been using that idea for some time on an Osprey 41" mono, Most of the Hor monos come with a stinger that has the same gap. i posted a reply yesterday on the HK Vanquish thread that had the same problem as the Osprey as their the same boat. I make the o rings out of 6mm id x11mm od exhaust silicon tube cut to whatever length you need. Martin.
    • dag-nabit
      • Feb 2011
      • 775
      Great idea JP, and Martin.
      I'll have to give that a try.
      Kevin
      • JPriami
        N4FOX
        • 1711
        That sounds like a good idea too Martin. This is the first boat I've had with that gap being a problem. I had the idea a few weeks ago. But i was already replacing the strut on mine so i never tried it. So i figured it would be good to try in this other Spartan. I figured I'd use a grommet because it would be a little more malleable. I did think about using hose or tubing at first.
        Great minds think alike.
        • wilsta67
          • Feb 2011
          • 203
          good idea!
          who's boat is that one JPriam?
          • JPriami
            N4FOX
            • 1711
            Friend of mine who lives in Florida. He sent it to me to do all the mods. Testing it this weekend then shipping it back.
            • wilsta67
              • Feb 2011
              • 203
              kool! hey its a bit quiet over traxxas without ya lol
              • martin
                • 2881
                ic engine silicon from any model shop is very pliable stuff & squeezes nice + whatever size gap you simply cut to length. Martin.
                • Shaun78
                  • Feb 2011
                  • 419
                  is that another stuffing tube because i have an extra
                  Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
                  (63.7 MPH) Traxxas Spartan (same setup)
                  • JPriami
                    N4FOX
                    • 1711
                    The rubber grommet seal worked great yesterday. Got back and pulled cable and it still had grease on it. It even had some inside the strut so that's a lot better. Before no grease was ever staying in the strut itself. And that can cause the bushing to wear out quicker.
                    • dag-nabit
                      • Feb 2011
                      • 775
                      Excellent
                      I have an assortment of grommets on hand, hopefully I have a couple that are the correct size.
                      Kevin
                        • 9481
                        Another good thread Justin
