Spartan Hatch Modification
  • dag-nabit
    • Feb 2011
    • 775
    I have been concerned about the hatch design on the Spartan after seeing a few videos (including JPriami's) where the hatch gets torn off when the boat flips.
    The two tabs that protrude past the back of the boat are believed to increase the chances of the hatch being dislodged, and possibly damaged in the event of a high speed flip.
    I thought about how to modify the hatch, and still have it function and look reasonably good. Here is what I came up with.
    First I filled in the back of the tab with pieces of fiberglass cloth and resin to beef it up. Then I sanded the tabs flat so the won't stick out past the rear of the boat.
    Tabs filled in with fiberglass and sanded flat.
    Then I painted the back of the tab where the plastic an fiberglass were showing.
    Here is a view from the top showing the tabs no longer stick out past the transom
    I think it still looks OK, in fact i suspect most people will never even notice it, and it will make putting hatch tape on a whole lot easier.
    Kevin
  • JPriami
    N4FOX
    • 1675
    Good idea!
    • JackBlack26
      • May 2007
      • 903
      How do you open it?
      • dag-nabit
        • Feb 2011
        • 775
        Originally posted by JackBlack26 View Post
        How do you open it?
        Large flat screw driver and a small hammer
        Kevin
        • JPriami
          N4FOX
          • 1675
          Im about to put mine back to 100% stock and send it out to sea with 2 sticks of dynamite where the batteries would go and show ya how I open mine up.
          • LarrysDrifter
            Big Booty Daddy
            • May 2010
            • 3278
            Post a video of it. We have to see that!!
            • dag-nabit
              • Feb 2011
              • 775
              • Panama Jack
                • Jan 2011
                • 21
                From my experiance the hatch flips open because it flexes in the midle and the tab that is in the front unhooks from the hull.
                • dag-nabit
                  • Feb 2011
                  • 775
                  Very possible, this may not be a complete solution.
                  But in one of JP's videos the back of the boat contacted the water and his hatch was ripped off and was broken around securing pin.
                  This will also make it easier to put on hatch tape.
                  I'm fairly confident it will help to some degree, and it didn't take long to do. Did the fiberglass/resin work in the morning and sanded and painted in the afternoon. Probably not more than 1 - 1.5 hrs total working time.
                  Kevin
                  • Wade
                    • 71
                    Kevin...where did you pick up the trim tabs you have on your boat? that transom pickup being mounted on one is a slick idea.
                    -Wade
                    • JPriami
                      N4FOX
                      • 1675
                      Think he got them from Jan at KintecRacing. They are sv27 tab adjusters. He opened the mount holes a bit to make them fit.
                      • Wade
                        • 71
                        Thank you for the info.
                        • dag-nabit
                          • Feb 2011
                          • 775
                          That is 100% accurate.
                          Kevin
