In hull pickups insallation.
  • JPriami
    N4FOX
    • 1675
    Im doing some modifications for a friend. One of them is installing in hull water pickups. The motor and esc are going to be upgraded as well so these will do a great job cooling the system. The stock rudder will be filled since it won't be used for cooling.
    Now I have to dremel out the inside on the first layer of the hull inside the lines. To fit the step up from the surface area of the pickups that are on bottom of the hull.
  • LarrysDrifter
    Big Booty Daddy
    • 3278
    Still playing with Wal Mart toys,Justin? ....kind of.
    • JPriami
      N4FOX
      • 1675
      Lol.
      • bwells
        • Jan 2009
        • 842
        I'm doing the same thing only on 3/32" balsa that I need to leave the 1/16th for the pickup. It would be nice to have the pickup with an 1/8th inch lip and fill with epoxy rather than cut down to 1/16". Hope you have a steady hand!
        • JPriami
          N4FOX
          • 1675
          I can do it :) there are two layers of hull in these boats. I can remove the first layer. And if it needs more I can lightly remove more. Then I will finish shaping the outer squares with fine files. I will put a peice of plexiglass on the bottom off the hull when placing the pickups to be epoxied down so I know they are flush with hull and I can see it.
          • bwells
            • Jan 2009
            • 842
            Got it. How about packing tape or wax paper between the hull and the plexiglass so the epoxy does not stick to the plexiglass?
            • JPriami
              N4FOX
              • 1675
              Not a bad idea.
              • JPriami
                N4FOX
                • 1675
                Finishing this up tonight.
                • Chilli
                  • 3067
                  Nice Job!
                  Mike Chirillo
                  www.capitolrcmodelboats.com
                  • JPriami
                    N4FOX
                    • 1675
                    Thank you
                    • bbosncali
                      • 756
                      looks great but gotta ask... where the heck are you running all these lines? dual pick up rudder now 2 more pick ups??? im pretty new to this but there is only so many places they can go lol... still makes me want them
                      miss gieco cc 1518 62.1mph [/COLOR][/B] Delta Force 33" cc 1717
                      • JPriami
                        N4FOX
                        • 1675
                        This one isnt my boat. I am upgrading one for someone else. We decided to keep the stock rudder but block it off and do the in hull pickups. Will be nice plus no hoses outside to see.
                        It will be powered by a cc1520 and t-180. I'll be putting those in tomorrow.
                        • bbosncali
                          • 756
                          Nice!!!!! I like the look very smooth!!! I guess it would help if I read the top paragraph lol
                          • wilsta67
                            • Feb 2011
                            • 203
                            copy cat!
                            [IMG] By wilsta at 2011-03-11[/IMG]
                            • JPriami
                              N4FOX
                              • 1675
                              Nope :) I was going to do it on mine but I made my stock rudder ugly. So I decided to do the dual rudder instead.
                              The first person I seen do the in hull pickups was here on ose back in feb I think.
                              Yours look staggered? Are they or is it just the pic?
