Spartan Rebuild
  • Nightstar
    • 3
    Spartan Rebuild
    Hi Guys,
    This is my first boat, bought it thinking it would be just as good as my E-revo...
    First run using batteries from my E-Revo 6s lipos, within a few mins the esc had a meltdown, wish I had my camera would have been a perfect video for Traxxas as it came to a stop in the middle of the lake then smoke pours out from the boat would have a had title like "2011 boat award for worst rtr ever"
    I would like to try and make this boat best as it can be.
    Any suggestions would be great, thanks Jpriami for leading the way
    Upgrades so far
    Water Lines - OSE Large 1/4" Tubing
    Water Outlets x2 - Traxxas Water Outlet PN: 5723
    Rudder - Speedmaster Dual Pickup Tapered
    Esc - Seaking 180
    Motor - Leopard 4082
    Water Jacket - Leopard 4070
    Batteries x2 - Hyperion S3 11.V 5000mAh 35C
    Prop - S220
    Trim Adj. - Traxxas PN: 5731
    Servo - Traxxas PN: 2075
    Second run with upgrades found collet not holding ,
    looking at replacing with AeroMarine, any ideas, thanks
  • wilsta67
    • Feb 2011
    • 203
    how did the hull fare did it warp the bottom and melt the nose of it??
    welcome to the fire brigade club lol
    • JPriami
      N4FOX
      • 1711
      Aeromarine or Octura collet would be good. As long as the flex cable isnt failing next.
      Sorry to hear about the burn up. This boat with it's award winning reputation, oh boy lol!
      • dag-nabit
        • Feb 2011
        • 775
        You know, there have been several suggestions for a more appropriate name for this boat.
        Considering the number of them that have been resurrected from the ashes, I think the "PHOENIX" would suit it well.
        Kevin
        • LarrysDrifter
          Big Booty Daddy
          • 3416
          Dumpster Diver is fitting.
          • JPriami
            N4FOX
            • 1711
            Lol. Your so blunt Larry. But I like that about ya.
            • Nightstar
              • 3
              Thanks for the info.
              Hull intact mainly internal discoloration
              Think ill try aeromarine collet and name it "phoenix"
              • shctexas
                • 158
                Here's a photo of my re-badged boat. http://i1197.photobucket.com/albums/...n/HPIM0188.jpg
                • Nightstar
                  • 3
                  Nice decal custom made?
                  Just been looking at all parts on the spartan since most are of poor quality, seeing what upgrades that I may have overlooked, see comparison below just for interest.
                  Stock vs Aftermarket
                  Water Lines
                  Stock
                  Traxxas Water Cooling Tubing
                  Inside diameter: .101" (2.5mm)
                  Outside diameter: .212" (5.5mm)
                  Aftermarket
                  1/8" Inside Diameter 0.125” (3.175mm)
                  1/4" Outside Diameter 0.25” (6.35mm)
                  Water Jacket
                  Stock
                  Traxxas Water Cooling Jacket Spartan
                  Rubber Construction
                  Aftermarket
                  Leopard 4070
                  Aluminium Construction
                  Motor
                  Stock
                  Velineon 540XL Brushless
                  1600kv 2pole
                  Aftermarket
                  Leopard 4082 Brushless
                  1500kv 4 pole
                  Esc
                  Stock
                  Velineon VXL-6s marine esc
                  80A continuous and 300A peak
                  12 gauge wire
                  Aftermarket
                  Turnigy/Seaking 180 marine esc
                  180A continuous and 360A peak
                  10 gauge wire
                  Esc/Battery Connections
                  Stock
                  Traxxas 50-60A
                  Aftermarket
                  3.5mm ec3 connector 60A
                  4.0mm bullet connector 75A
                  5.0mm ec3 connector 120A
                  5.5mm bullet connector 150A
                  6.5mm bullet connector 200A
                  Servo
                  Stock
                  Traxxas Servo P/N 2056
                  Torque: 80oz-in
                  Aftermarket
                  Traxxas Servo P/N: 2075
                  Torque: 125oz-in
                  Shaft Maintenance
                  Stock
                  Oil
                  Aftermarket
                  Grease
                  Last edited by Nightstar; 03-22-2011, 07:12 AM. Reason: Unable to Side by Side comparsion properply chaged to below each other
                  • shctexas
                    • 158
                    Yes sir. A guy in a kiosk at a the local mall made it. It looks like it belongs there, huh?
                    • dag-nabit
                      • Feb 2011
                      • 775
                      That it does.
                      That could the most profitable accessory for this boat, customized "slam" decals.
                      Kevin
                      • shctexas
                        • 158
                        I've removed all Traxxas badging and will use decals form the manufacturers whose replacement parts I've used ...to include OSE. A bit of a wise guy, huh?
                        • JPriami
                          N4FOX
                          • 1711
                          Maybe I should put some Italian flags on mine
                          • dag-nabit
                            • Feb 2011
                            • 775
                            I have removed all the Traxxas decals, but haven't added any others yet. I have left the Spartan sticker on.
                            • shctexas
                              • 158
                              Justin, as well you should. It's a great idea, I may include a Texas flag on mine....me being a proud, somewhat obnoxious Texan and all. The rear of the hatch deck seems like a good spot.
