6S users please check in here.
  • JPriami
    N4FOX
    • 1711
    I've been experiencing heat issues with the flex cable & stuffing tube on 6S.
    First bit I noticed was there was rainbowish discoloration on the stuffing tube when i took the tray out of the boat for some work I was doing. That discoloration is a sign of high heat.
    It also got so hot it began to melt the plastic holder at the back of the tray near the transom. This was noticed before my modification of moving the strut and tube btw.
    I grease my flex cable every one to two runs so there is no way it's a problem with not maintaining the cable with grease.
    Anyways i would like for all the 6S runners to check the tube for discoloration or at least put your fingers on it right after you run to see if it's really hot.
    The reason being is I experienced my flex cable sizing up today and not turning. Luckily my setup is over powered what happened was the boat stopped but the motor tried to spin the cable and ended up spinning the collet over the end of the cable. I sent the rescue boat to go get my boat thinking i lost the prop the way it was acting. Then got it back to find the driveline was binding. After the boat cooled down it spins freely.
    There could be a potential problem with the driveline sizing up and that could fry your eletronics IF this is happening.
  • shctexas
    • 158
    There's some good news! I appreciate the heads-up. I'm just about to complete mods and anxious to run it. I'll watch for the stuff tube issues. After all of your success and now this!
    • dag-nabit
      • Feb 2011
      • 775
      I asked this over on the other forum, but will post here for discussion as well.
      I thought I read in another post you replaced the teflon liner with a new one from a different manufacture. Were you still running the original liner, or was this latest heating issue on a new liner?
      Kevin
      • JPriami
        N4FOX
        • 1711
        I had heat issue with the stock liner and today on the first run with new one.
        I'm wondering if the stock traxxas cable is swelling up too much.
        Got couple pics I'm gonna post in just a few
        • JPriami
          N4FOX
          • 1711
          Top cable the stock traxxas flex. The bottom an aeromarine cable.
          There are a bunch of those shinny spots on the stock flex cable all the way down it.
          Keep in mind that cable was greased right before the 1st and only run.
          Also compared to the cable below the stock one the wires wound around are a slightly smaller diameter. And the cable seems to have more give to it if you grab and pull on it a bit you feel it separate. I'm wondering if it's so much flex it's swelling up too much and causing a bind, plus the expansion from heat of binding.
          • dag-nabit
            • Feb 2011
            • 775
            You know, I was thinking that same thing, but since I don't have a whole lot of experience with flex cables I didn't say anything because I just didn't know if it was reasonable.
            I was wondering with the big props, and plenty of power you are pushing with, if the the cable was maybe torque "twisting" (trying to corkscrew??) or as you have pointed out "expanding" the windings.
            Kevin
            • GeoVW72
              • Jun 2010
              • 258
              The point of the way a flex cable is layed is so that the coils tighten up under power and don't expand, cork screwing is definitely something I can see it doing though. I have also noticed that the one I have has a slight kink in it.
              The one concern that I have is where all the gunk keeps coming from when I clean the cable off.
              I have cleaned it out many times and blue grease keeps magically turning into brown gunk
              New liner that shows no wear and it was cleaned 20min after running it, I'm thinking that the assembly lube is still in the inner core and may be creating some wear/heat and causing the cable to expand. I think that the cables need soaked in a solvent to get the assembly lube out.
              I have a few runs on 6s without any major heat issues, although I have always ended up with a bit of water in the bottom of the boat
              Team Boca Bearings
              S&G Design
              • dag-nabit
                • Feb 2011
                • 775
                I kind of figured as much, that only makes sense. But since so many other things have gone sideways on the Spartan, I thought it might be possible something else was overlooked at the manufacturing level.
                As for the grease turning color, on my SV's the blue grease always turns a greenish/brown color after I run. I assume because of emulsifying with water.
                I'm not saying you don't have some other issue happening, just mentioning that discoloration of the grease seems to be the norm in my experience.
                Kevin
                  • 9481
                  Kevin
                  they make left and right cables, and the one on the spartan is correct
                  it will not come apart in the wrong direction
                    • 9481
                    sounds to me like another crapy part from Taiwan
                    • JPriami
                      N4FOX
                      • 1711
                      yeah I feel it is another crappy part. I am thinking of taking the stub shaft of and putting it on my aeromarine cable. I dont have a torch handy at home tho to heat it up to make the loctite release
                      • JPriami
                        N4FOX
                        • 1711
                        Just tried to run again with the stock cable. It's junk! It must be cork screwing because everything was in check and greased. It got hot as hell in less than a min. Caused everything to heat up trying to turn it too.
                        • JPriami
                          N4FOX
                          • 1711
                          I've been leaving about 1/4 gap for shrinking. Is it possible that's too much now and it's doing crazy stuff?
                          • dag-nabit
                            • Feb 2011
                            • 775
                            I've been e-mailing Jan at Kintec racing about the Flex cables. He is planning to stock upgraded cables and liners for the Spartan but doesn't have an oem stock one to measure up.
                            I offered to measure one up for him, but haven't heard back yet. I will understand if he isn't comfortable assembling one if he can't do the measurements hands on.
                            I'm sure OSE would do the same if we let them know there seems to be a need for better cables.
                            Kevin
                            • dag-nabit
                              • Feb 2011
                              • 775
                              Put a teflon washer between the dog nut and strut to protect stuff, and try a bit less gap to see if it works.
                              If the smaller gap is too tight, the wear should show on the thrust washer and you can increase the gap again.
                              Kevin
