Now lets upgrade some more stuff on the Spartan
  • JPriami
    N4FOX
    • 1711
    #166
    YouTube
    • ron1950
      • 3082
      #167
      looks like u really hit the setup this time j
      • tomjr
        • Feb 2011
        • 17
        #168
        very nicely setup spartan......
        Well almost perfect....
        • tomjr
          • Feb 2011
          • 17
          #169
          Can traxxas just bring back your boat and come out with a version 2......
          • JPriami
            N4FOX
            • 1711
            #170
            Thanks everyone. It's been fun and agrevating all at the same time.
            • shctexas
              • Jan 2011
              • 158
              #171
              Ok, questions. The wire drive...where did you get it? I recall that someone might make them for the Spartan. Can a drive that is too long be cut down to the correct length? The Sppedmaster you got here, correct? Great job! Tra**as should contract your skills for their next project.
              • JPriami
                N4FOX
                • 1711
                #172
                Yes got the stinger here on ose. the wire drive I got from Ben over at fightercat.com Jeff Wohlt makes them too rcraceboat.com They can be cut to length. Steve sells them too here on ose.
                • Shaun78
                  • Feb 2011
                  • 419
                  #173
                  in the manual on trim tab adj. says angle tab down will force bow down. If prop torque pulls boat to the right then wouldnt you angle the left tab down some to drop the left side bow to compensate? i set mine that way and it seems to run stable as long as batteries are more towards the front. Anyone else try that?
                  Genesis (Bosncali Geico Beater) Leopard 4082 1500KV
                  (63.7 MPH) Traxxas Spartan (same setup)
                  • JPriami
                    N4FOX
                    • 1711
                    #174
                    the torque will twist the boat hull to the right. that can be adjusted a little by right tab down. Ive found the boat doesnt twist as bad if you ease into the throttle. If the boats twisting really bad & cant seem to be adjusted out it can be a sign of the drive cable binding. Ive seen it many times on these boats.
                    • Bigbore
                      • 179
                      #175
                      Originally posted by JPriami View Post
                      The new stinger holds a 3/16" .187 propshaft. But the stuffing tube inside the boat to the motor is stock. For a .150 flex. But I'm running piano wire drive .078 into a .187 propshaft.
                      Like these.
                      Are you using a teflon tubing inside your stuffing tube? What's the outside diameter of your stuffing tube?
                      I have the same .078 wire drive with 3/16 prop shaft on my Titan 29" that I got used. From the beginning I had to fix the leak from the stuffing tube. In my case the stuffing tube were a 5/32" brass for Octura .098 Flex Cable ... I guess by measuring it and had no teflon tubing inside stuffing tube.
                      Now I have to test a new idea. A two pieces stuffing tube with a silicone tube (2mm inside diam. and 4mm outside diam.) that fits tight on the .078 wire drive and on the smaller stuffing tube. It could have more drag and in that case I will go back with the original stuffing tube.
                      One last question: What bullets are you using on the motor wires? The stock 4mm bullets of my Leopard 4074 are getting too hot and I will try the EC5 5mm type.
                      • JPriami
                        N4FOX
                        • 1711
                        #176
                        No GPS to use yesterday. It got wet and quit working on me. But it's no doubt doing low 60's in this clip. And I cant hold the throttle down for long it gains speed and becomes unstable again. Huh go figure. Lol
                        JPriami's Mono
                        • JPriami
                          N4FOX
                          • 1711
                          #177
                          BigBore I'll answer ur questions soon as I can. I'm not near the boats to check and measure right meow.
                          • dag-nabit
                            • Feb 2011
                            • 775
                            #178
                            JPriami's Mono
                            Too cool the way it wants to jump out of the water when you pin it. Almost like your cat now.
                            What prop are you running in the vid??
                            Kevin
                            • JPriami
                              N4FOX
                              • 1711
                              #179
                              I'm not telling yet that was a raw prop I need to finish so it still needs to be balanced and a little better sharpening. I just wanted to see if it was worth me putting work into finishing.
                              • Shaun78
                                • Feb 2011
                                • 419
                                #180
                                Awesome, I'll take it....
