Traxxas Spartan
  • Diesel6401
    Memento Vivere
    • 4203
    I've read over at Traxxas that someone is seeing 185-205* temps on the motor
    WHAT!!!!!!!
    *That's Crazy*
    - Diesel's Youtube
    - Diesel's Fleet
    • oscarel
      • Dec 2009
      • 2135
      Originally posted by jac4412 View Post
      Huh interesting... so it appears they came out with a great setup! Any info or comments on the handling and such? Thats funny... now that I think of it I'm wondering why no one brought up the heat concern before the release.... Going from a few nimh packs to racing 6s lipos is a huge jump... I wonder how these things will work in the summer. But thats cool... maybe I'll have to pick one up since theyre is such positive reviews!
      It handles great from what I did. Again it's not my boat and I'm trying to be as gentle as I can with it. It was a little windy today, 10+mph winds, and with the batteries all the way back it get's a little squirly but all in all a great handling boat. My only complaint is that the lid feels really flimsy and I wonder how long they're going to stand up to abuse. Also not a drop of water in the hull.
      So now back to the heat thing. I ran it yesterday for about 6mins with the batteries all the way forward so it was running very wet and that was the only way it heated up the motor. I would imagine which I'll test tomorrow that it was pulling around 130 amps easily running wet.
        • 9479
        what do you think your average amps is?
        because pulling 130amps running 6mins seams like a long run..
        • oscarel
          • Dec 2009
          • 2135
          Right on man!
          I just placed an order for one of these at tower to do some testing on 4s, 5s, and 6s
          I don't have an Eagle Tree, but I was going to do gps runs and see what happens on the stock prop and then try some others I have lying around
          and gues what the CC1520 is going into after my gps runs
          That will be interesting. The 1520 will need more prop than what comes on this boat and I wonder what that's gonna do to handling. I also wonder what this motor would do with a different prop.
          • oscarel
            • Dec 2009
            • 2135
            So if I take the 2 runs from the eagle tree data today the first shows average 43.37 and the second 49.62 with each run being about 130secs. The third run my GPS shows 3:06mins 0.46 miles so I would say about 2mins for this run. I'll put the batteries on the charger and see how much is put back into them. Batteries are 2 Turnigy 5000 3S in series.
            • oscarel
              • Dec 2009
              • 2135
              I put about 4700 ma back into the packs which included balancing. I'm headed back to the lake with 4S and 6S and I've got temp sensors on the front and back of the motor and RPM sensor hooked up. Hopefully the GPS will record this time.
                • 9479
                ok..
                that's pushing those packs taking them down to only 6% left in the packs
                  • 9479
                  so if we total your runs = 446 sec into the 4700mah, your average amp draw is 37.94amps
                  so if we take our packs to 20% left we would see run times of 6.33min or 380sec..
                  • oscarel
                    • Dec 2009
                    • 2135
                    ok..
                    But that's putting 4700 ma back into 2 5000ma packs correct??? On the charger cells are showing about 3.8v per.
                    • Make-a-Wake
                      FE Rules!
                      • 5554
                      Looks to me that with amp draw around 80, and spikes up to 120, along with the high heat mentioned(although not verified yet by osarel) that the prop size is somewhat maxxed out. Maybe a berylium prop of similar size would help it run a tad cooler and get a few more mph out of it.
                      • oscarel
                        • Dec 2009
                        • 2135
                        Ok, here's temp and amp data. Again the GPS unit didn't record. I've got to play with that a little more. I ran it on 4s until I got bored and then 6s. It took on some water today so I wasn't going to sacrifice my cellphone. 4s was a continuous run, 6s there are 3 runs. I had a Garmin 855 in and I recorded high speed of 44 but the boat was bouncing back and forth so I brought it in and removed the GPS. Second run it was also bouncing around and I found the rudder tilted up so I moved it back straight and went for the 3rd run. There is no place to hook up the eagle tree so I had a 1500 3s battery powering it and I would imagine the weight of that plus the GPS would add up almost to another 3s 5000 battery.
                        • oscarel
                          • Dec 2009
                          • 2135
                          Max temp after running was around 130 and it was still climbing after running as you can see. So I'm sure the 150 is possible with extended running. But as you can see while it's running the cool water will bring the temps down. ONE OF THE TEMPS SENSORS CAME LOOSE WHICH EXPLAINS THE BLUE LINE GOING LOW AND STAYING THERE ON THE 6S RUN.
                          • oscarel
                            • Dec 2009
                            • 2135
                            RPM data
                            • oscarel
                              • Dec 2009
                              • 2135
                              I stand corrected, I just put 4175 back into one 3s.
                                • 9479
                                That makes me feel better, that's about 16% left in your packs...
                                Did the LVC kick in durring the run?
