Re: $319 rudder... I don't use Chinese products on expensive, big gas boats...... I'd rather make them myself....
Traxxas Spartan
sounds like you had it setup right William!Originally posted by wilsta67 View Postthe middle of the tray is the best position for batteries.
done all the mods cooling jacket,bored out water pick up bigger hose, had esc set to race mode.
funny how still today some want to blame the user
Hum, I just scanned back and didn't see where I said it was the users fault. I was simply asking because nowhere did he ever say in this thread how he was running it. I know I'm guilty of getting a new toy and wanting to run it without reading the manual and only going back to the manual when somethings not right. I work in a customer support organization and have for over 20 years and there's always questions to ask that may help.... So I guess I'll stay out of this one for now. Good luck all.
You continued running a piece of equipment that was clearly exhibiting a known and acknowledged defect and this SURPRISES you?!?!?!Originally posted by wilsta67 View Post35c 5000mah in this video 42mph
and put in a set of 45c nano techs for the first time and this happens.
Gee, I wonder why the center channel came unsoldered
If that's not user error, I don't know what is
Uh I sure hope your not putting blame on a customer who is running this pretty much stock!Originally posted by GeoVW72 View PostYou continued running a piece of equipment that was clearly exhibiting a known and acknowledged defect and this SURPRISES you?!?!?!
this is not the only known esc to fail to normal use.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Idk, it's pretty plain as day there was a problem with his esc. That is on traxxas no doubt about it. The problem lays in fault of the user for knowing there is a problem being educated about issues and continuing to run the boat with defective equipment till it burnt up. Thus making the problem worse. And to top it off going to tell other owners of the boat what's it's top potential is in speed when the one he owns wasn't even peaking in rpms because of the problems it was having with the esc. I don't mean anyone any disrespct I'm just using plain and simple logic to examine the facts. I still think traxxas should replace his esc. It was defective no doubt. I just don't apprciate fueling the fires of hate with a bit of...Land, Sea & Air, A true RC Addict.
my question goes out to traxxas
Where are you?
Well said Justin... It ran fine after many mods, using only stock parts, but highly modified for plenty of water flow ... Temps never exceeded 100.. I have the same stock setup, ran ok for the kids on lipos... After around 10 runs on lipo, esc malfunction, but no fire... Again, it is a toy, but we'll see how traxxas steps up with their warranty... Drivetrain went back today... If it's repaired for n/c, then that makes good business sense... My intention has been to use all stock parts, to entertain my engineers, but no touching the electronics... I'm not a big fan of Chinese mfg, but that's the world we live in... In a few years, their quality will improve....
to funny!
some just don't get it.. traxxas is resposible for the esc and motor having issues
not a user issue, but manufacture issue
bad esc to start off with means failure no matter if we are using the stock Nimh packs from traxxas or using 6s on stock setup.. a bad esc will melt and let out the magic smoke
using a X447 or bigger prop (not stock prop) on the stock system without any runs first and causing the esc or motor to fail, could be called user error
running stock setup with failing parts, is not user error
have any idea how many Brushless Revo esc's that failed that were on trucks with stock gearing running 4s and 6s?
tons!!!
traxxas had to replace many esc's because of some issue from the manufacture of the esc
againg not user error, but customers seeing what there new trucks can do
That was my point about Chinese mfg... I have been dealing with it for many,many years... Not once has their first batch of anything been correct... Even after several revisions, the quality improves, but there are still bad products (out of spec) in every batch.... The reseller (traxxas) still has to sample each shipment until they become compliant... Even then, they should take random samples and run a complete test. That is why a warranty is very important on any new product..... That's why you don't see many Chinese parts on commercial aircraft..
interesting stuff manOriginally posted by Greek75 View PostThat was my point about Chinese mfg... I have been dealing with it for many,many years... Not once has their first batch of anything been correct... Even after several revisions, the quality improves, but there are still bad products (out of spec) in every batch.... The reseller (traxxas) still has to sample each shipment until they become compliant... Even then, they should take random samples and run a complete test. That is why a warranty is very important on any new product..... That's why you don't see many Chinese parts on commercial aircraft..
I did talk with someone at Traxxas last week about the issues and they think it is with the manufacture, as he says they did not have any of these heat issues durring testing ..
Guess its safe to say that the "Spartan" has worn off................................NEED PARALLEL CONNECTORS?? QUALITY 5.5MM, 8MM, 8 AND 10 AWG, GET THEM HERE:
Doubtful, we just scared off the first wave of noobs
there will be more
