Traxxas Titan
This topic is closed.
  • RareBear
    • Jun 2010
    • 28
    #241
    Can someone kindly explain the trim tabs via the Traxxas pic shown? I am aware of how trim tabs work & what they do - raising/lowering the bow for different water conditions - but the Traxxas trim tabs feature an "adjustment screw", but in the pic shown, the screw looks to be bottomed out on the tab with no adjustment left, and the tab "seems" to be at 0 degrees of trim when compared to the aft section of the boat - am I missing something here?
    If someone could fill in the blanks, I would appreciate it - thanks!!
    God bless - "Rare Bear"
    Isaiah 40:31
    • BondoBrushless
      • Feb 2010
      • 156
      #242
      I see a easy fix with a longer screw ?
      It's either a oversight prior to the pictureing taking or the kit will come with longer screws to adjust more trim and have directions for this included.
      • Rumdog
        • 6667
        #243
        Actually, the braket and tab are 2 separate peices. Take the screws out, and flip the bracket over if you need any neg. adjustment from the tabs. Most trim tabs are like this.
        • BondoBrushless
          • Feb 2010
          • 156
          #244
          HAH! Shows how much I know.
          • forescott
            Hopelessly Addicted to RC
            • 3009
            #245
            I think in the pic the tab is pushed down more than you think. Its hard to judge from the camera angle. Could be an optical illusion!
            • wakeboardfusion
              • 514
              #246
              To me it looks like it is pushed way down.
              • sailr
                • Nov 2007
                • 7128
                #247
                The top bracket is upside down!
                Mini Cat Racing USA
                www.minicatracingusa.com
                  • 9481
                  #248
                  That's what I'm thinking...
                  • 6S HYDRO
                    • 1325
                    #249
                    it could be upside down but it might not line up with the holes if flipped. would have to actually try it
                    • Jeff Wohlt
                      • 2740
                      #250
                      Why do you think it is wrong? You adjust the lead screw to push the bottom spring plate up or down. Looks normal to me.
                      www.rcraceboat.com
                      jwohlt5362@yahoo.com
                      • BakedMopar
                        No Mo Slipah
                        • Sep 2009
                        • 1743
                        #251
                        I have never run trim tabs the other way around.
                        • Rumdog
                          • 6667
                          #252
                          I see no issue here. Basically the same as speedmaster type tabs. They'll prob just end up parallel with the hull anyhow...
                            • 9481
                            #253
                            The adjustable trims should be flipped 180*
                              • 7512
                              #254
                              Another vid!
                              • BondoBrushless
                                • Feb 2010
                                • 156
                                #255
                                Lookin' Good !
                                I'm anxious to get mine !
