So a fellow member and I have been PM'ing back and for with questions he had about setting up his new Zonda and he asked for pictures so I figured I would make a post with pictures and links to the parts . So here we go. The if you order a TFL Zonda from Banggood it doesn't come with a Servo ,receiver or Transmitter. I'm going to try out my Flysky Knoble NB4 with the TFL .
For the servo I picked up a Traxxas 2075 https://www.amainhobbies.com/traxxas...UaAqcgEALw_wcB Fits perfect in the cut out for the servo.
I swapped out the TFL 2 piece flex/stub shaft setup for 1 piece Flex shafts from OSE https://www.offshoreelectrics.com/pr...-HD-zonda-twin. You should also pick up https://www.offshoreelectrics.com/pr...=oct-teflon-24 PN# oc187t-24.
After talking to someone else on another forum you should increase the length of the teflon tubing by 1 inch over the stock teflon tubing.
You will also need to buy new props http://www.dasboata.com/ I picked up a set OF 442's I think Chris also can make 1 piece flex shafts so you can email him and ask.
For the Rudder I picked up this https://rcboatbitz.com/product/genes...de-ge316blade/
I also decided to experiment a little bit and decided to Install a set of Wire drives from http://www.rcraceboat.com/ZelosUpgrades.html . I'm using a set in my Zelos Twin and really like them and after watching a video of someone on youtube that had installed his Zelos Twin 36 flex shafts in his Zonda I figured why not give it a shot with the wire drives. With a bit of dis-assembly trimming and re-assembly they fit right in.
) water line circled is the one exiting out (in the picture don't look like it's the highest point, but it is)
