Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 My Voracity is a prop eater - RcBoaters Forum
    • 4340
    Expensive day at the lake. Too windy for the cats so I brought just the V-bottoms today. Since I had so many batteries to run with, I was trying all of my appropriately sized props on the Voracity to see the difference in speed, motor temps, and if any of them could solve my steering pull issue.
    First up was an ABC 1815 that is my step down option from the 1915 that set my top speed of 62mph. It's a reliable prop and now that I finally fixed my teflon liner that would creep up and bind against the motor collet, I wanted to run it one more time to get a comparison on the electronics temperatures after a run. Everything was indeed cooler and I ran about 1mph faster than yesterday. Had a small nick on the rudder last night, never thought anything of it. Noticed a dull spot on one of the 1815 blades as I was swapping it out at the lake, didn't think anything of that either. fool.
    Next run was on an x450/3 reduced to 47mm. Faster at 58.8mph, but had more lift so the boat was running a touch wetter. Temps were all good, boat still pulled to the right. I brought the boat back in and all three blades were mangles, then the light bulb finally went off. My rudder was hitting the prop on hard left turns. Took out all three blades on the 450/3 and there was a sizeable scar on the rudder.
    2017-09-04 11.22.06.jpg2017-09-04 11.22.11.jpg2017-09-04 11.22.16.jpg2017-09-04 11.33.12.jpg
    • 4340
    Checked for interference with my tried and true ABC 1915, looked good, sent the boat back out. Ran much drier, just a fews tenths off my best speed at 61.5mph, but suffered a mysterious spin out like most of the other runs.
    One blade was damaged, again. Mind you, by this time of the day, I'm now down 4 Dasboata props and not having much fun anymore. It seems the new break away rudder design that I installed over the winter, swings in a larger arc than the original rudder design that I ran all last summer. I hadn't run any of these larger props this year as this boat hasn't seen much lake time yet. They all were fine last year, difference being the rudder change. The mount is also continually loosening on the transom. The lock nuts inside the hull might be sinking into the stiffening plate, which is made of Nylon I think. Regardless, the boat is being drydocked until I can sort out a new rudder solution, likely aftermarket. It's ironic, I installed this rudder over the winter because of the shear pin to prevent damage to my transom. First time out early in the spring, I slipped on the rocks and dropped the boat. Chipped the paint all to hell and the fall hit the rudder arm and cracked the transom anyway. So the part I installed to prevent damage has been wrecking havoc ever since. I predict a firery death once replaced.
    I would recommend against swapping over to the new Proboat rudder if you have an original on an older hull. If you want the security of a breakaway design, look elsewhere.
      • 4340
      Thanks to Joshua (shua), who just PM'd me pictures of the Kintec rudder he had successfully ran on his Voracity. It's unfortunate I can't just go and order the part from Jan, but I do have a full spec sheet to go hunting with.
      • boatsrnew2me
        • Oct 2016
        • 474
        your having a bad day
        • TRUCKPULL
          • 3293
          OSE has the same rudder.
          https://www.offshoreelectrics.com/pr...prod=ose-80050
          Larry
            • 4340
            Originally posted by TRUCKPULL View Post
            Yep, ordered it and it was delivered The other day. Hope to have it installed before the weekend.
              Should have text me. Lol. I have lots of spare parts. I have one of these rudders on my voracity and my m certain I have a spare.
              Put a shorter servo arm on the servo or move the linkage in a little closer to the rudder. That will shorten the throw.
              • Steve069
                • Jul 2017
                • 27
                Will this rudder fit the stock (revised hull) model without having to drill new holes? It looks sweet!
                [Pro-Boat Voracity 36-E] [Volantex Angry Shark 798-2]
                [Feilun FT-011] [UDI Tempo 002]
                  • 4340
                  No. The new rudder has 4 mounting bolts and they don't line up with the 2 existing holes. 8n theory, you could get away with only drilling 3 new hols, but trying to reuse one original hole is a compromise on location and doesn't really save any work. I've sealed up the original 2 holes with JB Weld and will drill the new holes next.
                  The new rudder has a pivot point more similar to the original rudder design so the swing arc of the rudder blade will be less than the revised proboat rudder.
                    • 4340
                    Got a box full of props today that look much better then when I saw them last. Thanks Chris!
                    • dasboata
                      • Dec 2010
                      • 3972
                      [ATTACH=CONFIG]153927[/ATTACH]
                      Your welcome Ryan !!!!
                        • 4340
                        Speaking of a box of props, did my latest box get delivered to you yet?
                          • 4340
                          Poor boat hasn't been in the water in over 2 years. Started to blueprint the hull after I figured out there was a bad hook causing the boat to pull to the right, and finally got it painted. While it was apart, I replaced the motor and ESC with a TP4060 and a ZTW 200A. Made a rear motor mount from carbon plate and modified the electronics tray so the new ESC would fit. Today I finished up rudder modification version 2. I installed a longer setback rudder with a custom mount to use the existing mounting holes from the previous TFL rudder. I could have just filled them and drilled new, but the solid carbon plate i made to reinforce the transom was too pretty to make swiss cheese of. I modified an OSE twin pickup rudder blade to fit in the TFL carrier and drilled out the hose barbs for better flow. Now I just need to run the cooling lines and install a second water outlet on the side of the hull.
                          IMG_20191228_181730.jpg IMG_20191228_181829.jpg IMG_20191229_102228.jpg IMG_20191229_102450.jpg
                            • 4340
                              • 4340
                              All of the cooling lines are now plumbed. I added a second hose pass through fitting on the transom as well as a second outlet on the side of the hull. I bought blue hose specifically for this build, but it made the interior look too busy so I stuck with black. Installed a new LMT collet because there was no room for a large MBP style. Programmed the ZTW esc with a programmer and linked the receiver to my transmitter. This boat is finally ready to hit the water as soon as the weather cooperates.
