How Long Does your 6s Batteries Last?
  • Keagan-Z06
    • Mar 2016
    • 970
    Hello All,
    For those of you running 6s total power, what is your estimated run time? I just got this boat and would rather it not shut off mid sea or river. I am running dual Dynamite 50C 11.1V 5000mAh packs.
  • Crash
    • Oct 2015
    • 313
    that's is the same lipos I run, I get about 7 to 9 minutes run time.
    MaxAmps has a set of 8000 mah lipos they say will give the Spartan 38 minutes of run time, that sounds impressive for a FE
    • NativePaul
      Greased Weasel
      • 2770
      If you get 7-9 mins on 5000mAh how is another 3000mAh going to get you another 29-31minutes or 4 times the runtime? MaxAmps are full of BS about that, as well as their "true C" ratings.
      • Keagan-Z06
        • Mar 2016
        • 970
        7-9 mins sound about right. When do you guys decide it's time to bring it in? Does the boat slow down considerably before the batteries die?
        • Mxkid261
          • Jun 2015
          • 734
          Lvc will kick in and boat will cut power when batteries get to certain voltage. 38 minute run times?!? Anything over a 15 minute run time on a fe boat is probably pushing it. I can get 10-12 minutes on my rivercat on 6s and its pretty warm after that. Im surprised a deep v can go over 30 minutes without turning into a cloud of smoke
          • Keagan-Z06
            • Mar 2016
            • 970
            How do I know if LVC is enabled? Is it something that occurs automatically? Sorry for the dumb ?s but I have never really ran the boat all out, just short burst and also because I was having receiver issues.
            • Mxkid261
              • Jun 2015
              • 734
              No dumb questions lol. I would assume it is enabled from the factory, but Im not familiar with the dynamite esc's. Your manual should tell you how to change it and how to tell if it is enabled or not
              • T.S.Davis
                • 6266
                It's impossible to even take a wild guess at run time without setup information. That's like asking how far I can go on a gallon of gas. If I'm driving a Prius..............pretty far. If I'm driving an M1 tank.....about 6 feet.
                7 minutes is a really long time for most FE setups.
                Noisy person
                • Keagan-Z06
                  • Mar 2016
                  • 970
                  Stock Voracity. No changes!
                  • T.S.Davis
                    • 6266
                    Lipo cells should never be drawn down past 20% remaining. You can go further but you're damaging the batteries when you do. The damage wont be evident at first. Over time though they will start to puff up. Then they start to get dangerous and should be disposed of properly.
                    We can work backwards pretty easy. 80% of a 5k pack is 4000mah to burn. 7 minutes of run time out of 4k works out to around 34 amps or so. I'm sure someone will chime in if my math is wonky.
                    Seems unlikely to me that the Voracity pulls 34 amps but I don't have one. Maybe Darin is watching. He knows the Voracity better than most.
                    Wild guess on my part would be that amperage is in the 70's on a Voracity with a modest prop. 5000's would give you about 3.5 minutes or so before the batteries are being injured. Anything more and you're going to kill the batteries sooner than you otherwise might.
                    Many use 3volts for the LVC but good batteries will give you 3v right down to 0% in the packs.
                    Noisy person
                    • Crash
                      • Oct 2015
                      • 313
                      The 150C Dual Core pack offers the highest performance of any lipo battery available in the world. Rather than using one 8000mah cell, we take two 4000mah 150C cells and put them together in parallel. By doing this, the power load is split between two cells(cores) instead of one. Each cell has the thickest and lowest resistance tabs available. Not only do you get two cores, but you get 4 tabs instead of 2. This creates a pack with the lowest possible resistance, the highest voltage under load, and the most rapid voltage recovery of any pack we have ever tested. The ultimate upgrade for your Traxxas Spartan boat. This is for 1 pair of our new 8000 11.1v Dual Core LiPo packs. These packs will make your Traxxas Spartan scream and will work perfectly with no modifications required! There is no better pack than this if you're looking for the ultimate combination of power and run time. If you're looking for an insane amount of power, these are the packs for you! Two Lipo 8000mah - 11.1v packs 55+mph in Spartan(22.2 volts) True 150C rating 32 minutes average run time(8000mah capacity) Lifetime Warranty 5C fast charge capable 100% waterproof Built today with factory fresh cells Built with genuine 12awg Deans Ultra wire We add the connectors and balancing taps for you 137mm x 45mm x 42mm, 600
                      • zooma
                        Local club FE racer
                        • May 2014
                        • 653
                        I don't know what a "dual core" pack is, but I would not even consider it with only 12 ga wire. That's inconsistent with 150C discharge rate. Just does not make sense.
                        Ron - The Villages, FL
                        • Mxkid261
                          • Jun 2015
                          • 734
                          Wouldn't 150C discharge rate be like 900 amps Lol? I have a hard time believing 12g wire can even handle that much current. I'd say maxamps is blowing smoke up ur a$$
                          • Monsterbrad
                            • Apr 2008
                            • 25
                            Anybody that reads this that runs FE boats knows that DEANS plugs are for cars and trucks not FE boats that are drawing over 60 amps.
                              • 9481
                              That's simply not true for real FE racing of this boat
                              taking 8000mah packs down to 20% left for a 38min run gives and average amp draw of only 10amps
                              I honestly hope your not talking about the most over rated lipos in the market called maxamps
                              we have been doing extensive testing for the past several years and maxamps almost always end up on the bottom of the list..
                              even Jang did a video in the past showing the same results of being very poor
                              one of our racers did testing for them and they puffed under real racing conditions
                              agreed...
                              our testing is showing REAL C ratings of good packs to be right around 40C constant
                              you are correct because they do not exist
