Improved Brushed motors
  • SJFE
    • 4867
    I know this is a shot in the dark here. Has any one looked into a brushed replacment for the motor? Im looking for some thing with bearings, vented, replaceable brushes that will still work with the factory esc.
    Thanks
    Tom
  • Steven Vaccaro
    Administrator
    • 8934
    Thanks
    Tom
    Tom there was some talk. Did you do any searching here?
    Steven Vaccaro
    • SJFE
      • 4867
      Not yet Sir. I'll try and set some time aside to dig around tonight after the kids are down.
      • marker
        • 38
        Tom
        The closest to the stock motor is probably the Graupner Speed 480 7.2 (6304).
        It's slightly larger diameter 29.3 V 27.7 mm and 30 grams heavier but it is more efficient .It doesn't have BB but I think they can be fitted , the brushes can be replaced with those out of a Plettenberg 200/20 motor (part No. 305000). The only 480 motor that Graupner lists that has BB is the Speed 480 BB 7.2 (6327) but it's rpm is approx 10,000 higher @ 7.2 volt . Also the shaft is 1/8 inch on the 480 motors.
        Mark
        • SJFE
          • 4867
          Thank you very much for the info Mark. I will look into them.
          • MINIz guy
            • Apr 2009
            • 2
            I'm not sure about this, but Atomic (R/C parts manufacture) sells 2 different 380 sized motors for car use. Their parts are all of high quality, but I do not know how a car motor will fare in a boat will less cooling.
            High Speed Motor
            High Torque Motor
            • SweetZ28
              • 1535
              aquacraft shows this motor on there site as a hop up for there new mini thunder so it should be better than the mini V stock motor also.
              WWW.PPRSLOTS.COM
