Someone double check my order
  • aquinosteven
    • 52
    So i just picked up a used mini v. Im looking to keep it cheap (under $100) I would like to stay brushed maybe a 480 but i still gotta find a reasonable ESC. Im not running Lipo. Anyway Im keeping the outdrive but i just want to change the prop shaft.
    Prop shaft
    http://www.offshoreelectrics.com/pro...od=oct-ocgcss4
    5/32" brass for Octura .098 Flex Cable.
    http://www.offshoreelectrics.com/pro...rass-tb&cat=70
    Now i just need a prop. Any suggestions. (Please link)
    traxxas villain EX, mini v
  • Diegoboy
    • Mar 2007
    • 7443
    Octura X430 Sharpened & Balanced
    Or
    Octura X430 Raw
    • aquinosteven
      • 52
      you think i could get away with the unsharpened one? and is the prop shaft right?
      • Diegoboy
        • Mar 2007
        • 7443
        No. It will need to be balanced.
        I used a 1/8 prop shaft (the one you list is a 4mm - slightly bigger in the strut or outdrive then reduced to 1/8 for the prop)
        The one I used was This.
        • aquinosteven
          • 52
          So there im just using the shaft. Do i have to convert to the flex cable when using that shaft?
          • Diegoboy
            • Mar 2007
            • 7443
            Ahh. Ok. Use the one you selected, you may have to enlarge the outdrive bore to accept it.
            • aquinosteven
              • 52
              yeah, I was planning to drill out anyway to accept the 5/32" copper tube
              • Diegoboy
                • Mar 2007
                • 7443
                You're good then!!
                • aquinosteven
                  • 52
                  Thanks a ton!
                  • befu
                    • Aug 2009
                    • 1064
                    I run a 430 or 431 on mine stock, plastic.
                    I use an octura 1/18" prop shaft and replace the u joints with .093 flex cable, but keep the 3mm solid drive shaft. Cheap conversion that way, I had to do 6 of them!
                    Brian
                    • aquinosteven
                      • 52
                      Ordered up the prop and the shaft along with a new u joint. Mine was all rusted. had to drill it out to get the old prop shaft out. Looks like its staying this way for now but i wanna run the mini car hardware in the future. I found it on there website, i just gotta pair it all up.
