Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Pro Boat mini v brushless conversion ! - RcBoaters Forum
  • lucozader
    • 144
    here is the boat ^^
    It was a nice clean install, but i stepped on the boat when getting out of the bath, so it's a bit rough looking now, i also had a mini rio sticker set so i stuck it on after fixing the damage
    Link to Hardware
    i used the following rudder, propshaft and strut from this combo deal ^^ these mini rudder and struts are all over ebay and probably on OSE as well,
    Here is the hardware installed ^^ I originally had the rudder higher up, but turning was not good, so i lowered it and bolted it on near the bottom of the hull, turning is great now
    Here is the boat, the water outlet is just some silicon tubing through a hole and finished off with epoxy for a snug fit. The water inlet is built into the rudder.
    silicon tubing
    I used silicon tubing with 2.5mm internal diameter ^^
    Here is the internals, the receiver is baloon sealed^^
    http://www.offshoreelectrics.com/pro...oct-oc098r-24c
    I used .098 flex cable from OSE ^^ the drive dog etc. were used on another boat
    http://www.offshoreelectrics.com/pro...d=ose-2bld-3mm
    i used the 27mm propeller ^^^ from ose, originally i used a bigger propeller, but it upset steering too much, 27mm works great
    http://cgi.ebay.ie/Hobbywing-Seaking...item414c1c33ea
    i used the seaking 35a esc, it is water cooled and works great
    http://cgi.ebay.ie/2604KV-water-cool...item45ef6ee591
    i used a 2604kv brushless motor, that cmes with a water cooling jacket, the motor works great on 2 or 3 cell lipos, it's really fast, the jacket keeps it ice cold
    http://cgi.ebay.ie/ETTI-Flex-Cable-C...item4837fffe1c
    i used the above flex cable coupler to attach the motor to the flex cable, i used a piece of brass tube to shim the motor end to fit snugly. The motor shaft is a bit too narrow for the collet.
    The boat runs great on the above 2 cell battery, the above 3 cell battery turns it into a bullet. I tend to use a 3 cell straignt line for speed runs. I use the 2 cell for turning and flips, when i time it right i can do a really nice 180 trick with this boat.
    I will post vids later.
    Thank you
  • lucozader
    • 144
    water cooled seaking 35a esc and 2604kv brushless motor ^^^ perfect for mini brushless boats
    http://www.offshoreelectrics.com/pro...prod=ose-80046
    http://www.offshoreelectrics.com/pro...prod=ose-80048
    ose have the strut and rudder in stock
    • lucozader
      • 144
      here is the boat on a 2 cell
      • lucozader
        • 144
        i used the stock brass tube as my drive shaft
        it works fine with the .098 flex cable, just grease it occasionally
        MY GREASE
        some people replace the brass tube with a bigger one and put in a teflon liner
        this is a tricky job, i did it on another mini v, i will show that later on
        there is no need to replace the stock brass tube and there is no need to use a teflon liner
        • 97sfeclipse
          • Mar 2010
          • 6
          Thank you for all the links to all those parts. Its helping me big time. Only thing I dont see is the parts for the water cooling. Can you explain exactly what was needed for that too? Just got my stock new mini v a couple days ago and ran it on stock battery one time yesterday for 5 min and was so depressed I put it up. Was rediculously slow, barely leaves a tiny wave behind it. If I were to guess I would say 3 to 4 mph max. Seems like there may be some binding in the driveline or something. Will try it again on 2s lipo after I grease the driveshaft but am putting in the order for all those parts you listed. Thanks alot for your time. T.
          • lucozader
            • 144
            the motor came with the orange water cooling jacket on it
            the esc has a water cooling plate on it as standard
            the rudder has a built in water pickup
            if you get the above parts and the tubing below it should be all you need
            http://cgi.ebay.ie/Brand-New-Silicon...item45ef6ee095
            run the tube from the rudder through thr rear trnsform in/out of the motor/esc and finally out the side of the hull
            • lucozader
              • 144
              here is the boat on a 3 cell :)
              • 97sfeclipse
                • Mar 2010
                • 6
                That is just awesome man. Good job.
                • 97sfeclipse
                  • Mar 2010
                  • 6
                  Does the stock motor mount work with that watercooled motor sleeve on the motor? If not what did you use? Are there any motor mounts that are easy to install in the mini v? I'm thinking about trying the fiagio 380L 8L 3633kv motor. Will that fit length wise in the stock motor mount? Thanks, T.
                  • 97sfeclipse
                    • Mar 2010
                    • 6
                    Between the fiagio 380L 8L 3633kv motor and traxxas 380 brushless 4000kv motor out of 1/16 revo which do you think would last longer and run cooler? I have a hobbywing seaking 50A watercooled esc. Thanks, T.
                    • lucozader
                      • 144
                      the motor i used is a bit too narrow to fit snug into the mount
                      it still is solid in the stock mount though, i put a piece of foam between the metal bracket and the motor and it holds it fine
                      also the stock mount catches one of the water outlets on the motors water jacket which helps to hold it
                      the stock motor is a 380 motor so a 380 or 380l motor should be a direct fit, if they are not water cooled
                      i put a 4000kv 380 motor in a mini c and i found it would not plane on a 2 cell but it was very fast on a 3 cell.
                      i think 2600kv is the optimum kv for this size of boat
                      i used a 2000kv and it was too slow
                      i used a 2600kv motor and it suited me fine, good speed and control on 2 or 3 cells
                      i used 2 different 3600 kv motors and they were only good on a 3 cell and difficult to control
                      i used a 4000kv motor and it was only good on a 3 cell and was difficult to control, it was a nice snug fit though
                      • 97sfeclipse
                        • Mar 2010
                        • 6
                        Anybody sell those watercooled 2600kv motors at a good price here in the states? Was hoping to not have to wait 3 or 4 weeks for shipping from Hong kong. Thanks, T.
                        • lucozader
                          • 144
                          i don't know about that
                          i am from europe and buy most of my stuff from china or europe
                          you could always try and buy a 380 size brushless and add a water jacket to it
                          if you want a motor quickly, sorry i could not be of more help
