Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Warning: Trying to access array offset on null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Brushless mini v - RcBoaters Forum
Brushless mini v
  • lucozader
    • 144
    Brushless mini v
    here is the boat ^^
    It was a nice clean install, but i stepped on the boat when getting out of the bath, so it's a bit rough looking now, i also had a mini rio sticker set so i stuck it on after fixing the damage
    Link to Hardware
    i used the following rudder, propshaft and strut from this combo deal ^^ these mini rudder and struts are all over ebay and probably on OSE as well,
    Here is the hardware installed ^^ I originally had the rudder higher up, but turning was not good, so i lowered it and bolted it on near the bottom of the hull, turning is great now
    Here is the boat, the water outlet is just some silicon tubing through a hole and finished off with epoxy for a snug fit. The water inlet is built into the rudder.
    silicon tubing
    I used silicon tubing with 2.5mm internal diameter ^^
    Here is the internals, the receiver is baloon sealed^^
    http://www.offshoreelectrics.com/pro...oct-oc098r-24c
    I used .098 flex cable from OSE ^^ the drive dog etc. were used on another boat
    http://www.offshoreelectrics.com/pro...d=ose-2bld-3mm
    i used the 27mm propeller ^^^ from ose, originally i used a bigger propeller, but it upset steering too much, 27mm works great
    http://cgi.ebay.ie/Hobbywing-Seaking...item414c1c33ea
    i used the seaking 35a esc, it is water cooled and works great
    http://cgi.ebay.ie/2604KV-water-cool...item45ef6ee591
    i used a 2604kv brushless motor, that cmes with a water cooling jacket, the motor works great on 2 or 3 cell lipos, it's really fast, the jacket keeps it ice cold
    http://cgi.ebay.ie/ETTI-Flex-Cable-C...item4837fffe1c
    i used the above flex cable coupler to attach the motor to the flex cable, i used a piece of brass tube to shim the motor end to fit snugly. The motor shaft is a bit too narrow for the collet.
    The boat runs great on the above 2 cell battery, the above 3 cell battery turns it into a bullet. I tend to use a 3 cell straignt line for speed runs. I use the 2 cell for turning and flips, when i time it right i can do a really nice 180 trick with this boat.
    I will post vids later.
    Thank you
  • lucozader
    • 144
    There is no need fora TEFLON TUBE to go over the flex cable.
    Just use the stock brass tube and a .098 flex cable, and remember to grease the cable occasionally
    I replaced the brass tube on another mini v to accomodate a teflon tube and it is a hard job
    there was no difference in behaviour at the end of it all
    • lucozader
      • 144
      water cooled seaking 35a esc and 2604kv brushless motor ^^^ perfect for mini brushless boats
      • lucozader
        • 144
        http://www.offshoreelectrics.com/pro...prod=ose-80046
        http://www.offshoreelectrics.com/pro...prod=ose-80048
        ose have the strut and rudder in stock
        • lucozader
          • 144
          this is the boat running on a 2 cell
