My Meltdown
  • DSC1
    • 85
    My Meltdown
    Put the boat in the water for the second run after changing to 5.5mm bullets and smoked the ESC. Spoke to tech support and they said to send them pics and hopefully would hear back about a new boat or new ESC and Motor. Burned enough to discolor the hatch and surrounding areas of ESC.20131016_201459_resized.jpg20131016_201442_resized.jpg20131016_201521_resized.jpg20131016_201354_resized.jpg
    Anybody else had one like this?
  • dirtdudesdad
    • Sep 2013
    • 1
    Yup mine did the same thing on the second run after buying it new. I sent pics of the boat and esc to Horizon and they sent me a whole new boat. It had bubbled the bottom paint, almost a hole in the boat. Hats off to Horizon, they had me back in the water in less than a week. By the way, I was running the exact 6s packs that it listed on the box.
    • DSC1
      • 85
      After a 2 to 3 week review of my boat they are finally sending me a new one. Hope to have it back Friday. I think I'm gonna move down to 4s. Maybe it will last a little longer that way??
      • seabird1
        • Mar 2012
        • 2
        Hi.. This problem is known to Horizon Hobby. Blackjack 29 suffers in exactly the same way. Its the 1800kv motor thats fitted to blackjack 29 and impulse 31 that cant cope with 6s, it overheats. They say if you want to run impulse 31 or blackajck 29 on 6s that you should fit the lower revving 1500kv motor from the miss geico 29. Iv'e tried it and it works pretty well, no overheating issues!.....
        • drewluvskarin69
          • Feb 2014
          • 5
          I smoked my motor & esc while running 6S lipos today. Ran fine yesterday, with all temps 90F or below. Today it's a stinking black mess.burnt1.jpgburnt2.jpg
          • DSC1
            • 85
            Got a new boat finally and started a few upgrades to prevent the first episode hopefully!!!
            This is a swordfish pro 220 for 6s and a Sirius 1512. Hopefully have some videos to post soon.
            • DSC1
              • 85
              Here are some before and after photos as well.
                I don't care what proboat says, you cannot run 6s on an 1800kv motor in this hull and expect it to last. I just don't understand why they would do something like this.
                On a side note, I have two 1500kv miss geico 6 pole motors that I'd even swap for the 1800kv version provided yours are in excellent shape because mine are. Pm me if interested.
                • drewluvskarin69
                  • Feb 2014
                  • 5
                  I'm interested in a trade.
                  KFXGUY, I've got one 1800kv motor I'm willing to trade. It's the new one from my replaced Impulse 31 V2.
                  PM me if interested.
                  • BHChieftain
                    Fast Electric Addict
                    • 2051
                    There are MANY threads of people frying the ESC on 6S. The reason is this-- while the ESC is rated for 22.2 volts, it is only an 80A ESC. So if you keep the stock prop on the boat, all it takes is a little hop out of the water and when the prop unloads and reloads, you get an AMP spike that kills it. The only safe way to run 6S stock is to drop down to a very small prop, like X440. But that slows the boat down... better off running 4S with a larger prop like x642.
                    Another problem, as mentioned above is 1800kv on 6S is really high RPM, a better 6S motor is the 1500kv.
                    If you want a 6S boat that is reliable, you should use a 180A ESC.
                    Chief
                    • Spartanator
                      • 1060
                      Chief
                      I am unsure of the hull efficiency of this model but almost no matter what hull (Cat or V) you should never run 6s on ESCs that are not rated for 180 AMPS continuous... Example: Spartan (V2 Castle setup) states it has 90 amps continuous but with a 300 amp burst... That does NOT make sense ratings wise, especially since I have been through 2 of those stock ESCs... Not touching 6s again with my Spartan... I would recommend that your battery wires are shorter, yours seem a bit long. Seems odd that they put the 6s on the box... They should have put flames around the ESC picture...lol
                      • Luck as a Constant
                        Make Total Destroy
                        • Mar 2014
                        • 1952
                        I've said it before and I'll say it again...
                        With the wealth of knowledge about fe boating on this forum and others, how in gods name do these companies make mistakes like this? Traxxas and proboat make 6s boats with 80 amp escs..... It's just stupid..
                        • Darin Jordan
                          • 9446
                          If you look carefully (well, you don't really need to look that hard!), you'll notice that the replacement 1800KV motor is considerably different than the previously supplied version. It's a "substantially" improved motor. I'd highly recommend it if you can get it in trade!
                          Darin E. Jordan - Renton, WA
                          • Spartanator
                            • 1060
                            No mistake, no mistake at all.... It's so you buy it, and many do.... I think it's called a Marketing Tactic....lol, I was just visiting the Traxxas forums and there they go again blocking more things that don't have Traxxas in the same sentence... Lovin' OSE! But it is a Mistake, with a capital M!
                            • DSC1
                              • 85
                              Ok so I got it in the water and have my first video. Water was a little rough and so is the video and my driving.
