were to buy the water hose nipple to the rudder or new rudder?
  • waterproof
    • Jul 2013
    • 239
    Hi!
    I have broken the screew nipple back of the rudder on the im31 v2 there the water flows, the "waterpicup screew nipple"
    I couldnt find a Complete rudder With this screew mounted, its sold out. And i only need this little screw there the hose is mounted on the rudder, i have been in the rc shop in my town a few but no one have a screew that fits the treads to the rudder.
    The Geico water nipple was a little to big and i fast broken when i trying to screw it on..
    Let me know if someone know where i can order this small screw or maby the hole rudder if i must buy it Complete, i think its 3,5mm screew and Geico have m4?
  • BHChieftain
    Fast Electric Addict
    • 2051
    Are you talking about where the water hose connects to the rudder?
    If so, could you try reaming out the threads and use a piece of brass tubing?
    I have a few boats that do not have threads on the rudder and I just use brass tubing...
    Chief
    • waterproof
      • Jul 2013
      • 239
      Yes this little screew that the hose gets water from the rudder :)
      I couldt find it and most of the shops is sold out. I have use glue but the treads is gone, i dont know how long it will hold so i want a new screew to fix the problem.
      Do you just buy a piece that fits the hole and just glue it?
      • waterproof
        • Jul 2013
        • 239
        I have ordered this part at 4mm http://www.modellers.com/Produkter/F...000006986.aspx
        And this 3,5mm http://www.modellers.com/Produkter/F...000001032.aspx
        The problem is that the hole in the middle is to small so i dont think the boat will get enough water..
        Can someone find the right part that i could order? I will be thankfull :)
        • BHChieftain
          • 2051
          For the brass tube method, for my rudder I got lucky and found a diameter that just barely fit-- it was very close but slightly too big so I was able to sand the brass tube to make a perfect press fit. You could also epoxy it in.
          Here's a link to the replacement rudder in case you can't get it to work.
          Chief
          • waterproof
            • Jul 2013
            • 239
            I understand. Horrizon hobby is also sold out. All places it just stand backordered so i think the proboat dosent have make enough parts yet to the impulse
