.187 flex shaft problem...
  • Stephavee
    I like cool things!
    • Jan 2011
    • 240
    So I made the jump to go with the .187 HD flex shaft and it seems like without the Teflon liner it will be too loose. Is this ok?
    " Do you really need anouther boat "
    YEP!
    Yes. You could use a strut bushing at the end to center it if you wanted to. You don't have to be I recommend it.
    • Stephavee
      I like cool things!
      • Jan 2011
      • 240
      You don't have any problems with vibration or wiping of the flex shaft? I will try to dig up a bushing of some sort...I was just wondering how you keep the water out and the grease in? Post pictures of your impulse 31's with the .187 flex shafts installed.
      YEP!
      • Stephavee
        I like cool things!
        • Jan 2011
        • 240
        So nobody has any pictures....
        YEP!
        • wiljm
          • Aug 2013
          • 40
          I've had this setup for 2+ years. I do not have issues with water leakage as long as I frequently grease the thing. It does make a lot of noise, but it runs great.
            Sold mine. What I do is make a 1" long bushing out of brass that slips over the flex with no slack. Then solder it in the end of your stuffing tube or use loctite or permatex sleeve retainer.
            • T.S.Davis
              • 6266
              More importantly is that the shaft is under sized. I had trouble getting my coupler to hold when I got one like that. Had a heck of a time figuring out what was wrong with it.
              Noisy person
                O dang. Didn't see the shaft measurement. Not good! It might be ok in low power situations, anything other than that it's probably gonna slip.
                  Most 3/16 flex cable will not measure 0.1875". its usually under by a few thousandths.
                  • T.S.Davis
                    • 6266
                    Ray, remember that P Wildthing I used to run? Kept spinning the shafts in it. That was the problem.
                    Noisy person
