newbie with Impulse 31 v2 some questions and damage
  • mosfet
    • Jul 2013
    • 13
    Hi there
    first of all i am Marco from the netherlands
    being doing rc for several years now but mainly cars (drifters and speedrunners)
    since 2 months ago decided to buy a second hand or used Proboat which the previous owner did float 4 times and stoped and then did sell it to me
    at first boating it on 4s i thought whooo but i did notice the hopping at high speeds or full throttle
    so went to Fuzzy tuning with it which trimmed it for me and it was much better by then
    2 weeks ago :
    i did hit the shore (wood) or something in the water and did have some damage
    so did my google is your best friend stuff and came out here on this great forum
    the damage i have is a cracked prop , a damaged flex axle and the motor mount is shoved
    so
    also did read many topics on this site and did follow Darian his topics about the Impulse proboat stuff (which is very awesome and much to learn from there for me)
    so by then i was not very happy
    now i got a couple of question for you guys
    1- i see a lot of you float with the Impulse 31 v2 on 5s but what do you guys run ?
    1x2s and 1x3s or a single pack 5s and can somebody show me the mod to run a single 5s on the battery tray ?
    2- wanna go 5s but did see i need to upgrade the prop -> can you guys give me a link tot the right prop ? which i need
    i wanna go as fast as i can with the stock motor and esc but still keep it safe
    3- i did order the straight turnfins from which Darin came up with !! was or is that a good choose and will i see improvement with this mod ?
    4- i see you can go dual rutter on this one , but did also see its for the Impulse v1 so will that conversion fitt a Impulse v2 also ?
    5- do i need another motor mount bracket ?
    also understand that i need to upgrade the motor connection bullits connectors to bigger ones
    the first thing i did today was buy a better motor coupler which is on his way now to my country
    also i order the bigger bullits and wanna go for dual rudder conversion
    from here i will be happy to hear any advise tips or other good stuff
    i will be happy to hear from you guys with any advise or tips
    i did run it 3 times on 6s with stock setup and its crazy fast but a little overkill in my opinion
    so gonna take it to 5s with a little modding
    for now thx for reading this topic (great forum with great info and projects)
    kind regards
    mosfet
    the netherlands
  • waterproof
    • Jul 2013
    • 239
    Hello.
    I also run my original Stock impulse 31 v2 on 5s. 1x2s 5200mh 30c and 1x3s 5200mh 30c and it fast enough. Stock prop and everything is Stock. Its must faster than the 4s batteries.
    I have 2x3s but i havent try it yet on 6s because im afraid to burn somthing up, after a Google search its looks like the impulse v2 will run fine on a Stock boat if you use Stock prop but im not sure..
    Any advice i can give that it will work Perfect on 5s and it more fun to drive on 5s than 4s.. So maby the best way is to keep it Stock on 5s to not get trouble..
    The dealer there i buy my boat says it will run fine on 6s if i keep the Stock prop on and not change it to a bigger..
    I will also like to drive it to 6s but its looks like its a risk..
    • iop65
      • Mar 2013
      • 367
      i converted mine for a single 5s lipo
      graupner carbon props do very good 40- 42 mm ,used the 42 with the stock motor on 5s ( was about the limit for this small motor)
      properly tuned driveline = it's like on rails ,chop or flat it's glued to the water!
      greatings from belgium
      • BHChieftain
        Fast Electric Addict
        • 1964
        Make sure the stock prop you have is sharpened and balanced-- it will add speed and reduce vibes. The Graupner CF props IOP65 mentions are nifty since they don't need to be s/b. Not quite as fast and will break more easily, but they are very low cost and way better than the stock plastic props that come on some of the boats.
        On the 5S, you can do it either way. If you switch to bullet connectors you can connect the lipos directly into each other in series and get rid of the harness.
        Chief
        • mosfet
          • Jul 2013
          • 13
          THX for your time and advise guys
          can somebody hit me up with a link to the prop that i need and can be used on 5s with stock esc and motor? would be cool
          still got a few questions left like : i see that many PPL are using a better and improved motormount , so whats up with that ? do i need that on 5s or keep the stock mount ?
          @iop65 -> thx for the help en photo (you rock) my Belgium neightboor :-)
          @chief -> also you many THX for the advise
          @waterproof -> thx gonna do the 5s thing now instead of 4s
          • iop65
            • Mar 2013
            • 367
            i put in a leopard 3674 1700 Kv ,it is heavier then the stock motor and i'm a carefull guy so i put in a mount also that supports the motor at the back
            and it looks better ,deanodysed the ugly orange
            • mosfet
              • Jul 2013
              • 13
              i did see that you got another motor iin that picture you showed me
              looks simply amazing
              still if someone can provide me the correct links to bigger props which will fit i would be pleased
              the stock one is cracked and i want a bigger one for the 5s setup
              • mosfet
                • Jul 2013
                • 13
                i did see this topic is in the wrong section and its for the v1 and this thing i own is a v2
                sorry
                iop65 thx for the great info in your PM
                You rock
                • BHChieftain
                  • 1964
                  Hi,
                  The boat is awesome on octura x642, but that will probably kill the stock ESC eventually on 5S (I'd recommend a 180A ESC). If you are going to stay with stock ESC on 5S, you need to use a smaller prop-- octura x440, and maybe octura x442 (but check temps and just be prepared if the ESC dies. If it were me I'd give the x442 a go, but it depends how much you want to protect your stock ESC).
                  If you can get your props sharpened and balanced then use these
                  Octura x440 (ok on stock ESC)
                  http://www.offshoreelectrics.com/pro...?prod=oct-x440
                  Octura x442 (risky on stock ESC):
                  http://www.offshoreelectrics.com/pro...?prod=oct-x442
                  Octura x642 (if you upgrade the ESC):
                  http://www.offshoreelectrics.com/pro...?prod=oct-x642
                  The OSE store Graupner props are all 1.4 pitch (same as octura x4's):
                  K-series 40mm (like octura x440)
                  http://www.offshoreelectrics.com/pro...od=grp-2317.40
                  K-series 42mm (like octura x442)
                  http://www.offshoreelectrics.com/pro...od=grp-2317.42
                  Chief
                  • mosfet
                    • Jul 2013
                    • 13
                    THX Chief
                    i did order the Graupner 42 MM k serie prop
                    also sold the stock esc and bought a second hand but brand new 120a Seaking esc
                    did bought the OSE straight turnfins from here and the stronger flexshaft
                    i did repleace the stock bullit connectors for 5,5 mm and did a motorcoupler
                    planning to run this on 5s
                    i am building it up now
                    • mosfet
                      • Jul 2013
                      • 13
                      maybe a mod can redirect this topic to the correct one -> the impulse v2 section ??
                      • iop65
                        • Mar 2013
                        • 367
                        looking good Marco!
                        what is the size off the "tube" (krimpkous) you put on the ec-5 connectors?
                        • mosfet
                          • Jul 2013
                          • 13
                          Originally posted by iop65 View Post
                          looking good Marco!
                          its from a Box from Conrad electronics with all kinds of sizes
                          the one i used says innersize is 18 mm and 90 mm long
                          i cut those in half and put that on two ec5 connectors
                          i did send you a pm with the link to the set
                          • iop65
                            • Mar 2013
                            • 367
                            thankx Marco!
                            • mosfet
                              • Jul 2013
                              • 13
                              no prob my Belgium friend
