T-180a placement
  • G-UNIT
    • 971
    T-180a placement
    As the title says, where do most of you place the t-180a in the impulse?
    I have put it on the left or port side, but its a tight fit and hard to run the wires, so this time i'm thinking about putting up front infront of the batterys, i did cut some of the tray sides away to make clearence for the battery leads.
    testing will tell about cg and running profile but just like to know from those who run the 180 where they put it.
  • G-UNIT
    • 971
    Any body?
    • stadiumyamaha
      • 1371
      I put a cf tray next to rail and mounted the 180 on it. I'll get you a pic.
      • stadiumyamaha
        • 1371
        • stadiumyamaha
          • 1371
          I epoxied the tray to the hull and the top of the rail. Works well.
          • G-UNIT
            • 971
            Thanx for the pic, thats about how I have mine located but without the tray,I think I will come up with somthing like that.
            I could not help to notice that your cooling you motor first, most all cool theie esc first jmo, again thanks for the pic.
            • stadiumyamaha
              • 1371
              Yea I normally run it to the esc first but was short on tubing when I put it together. It runs so cool on 4s that I haven't worried about changing it.
              Thank for the heads up though.
