Impulse OSE upgraded HD driveshaft question
  • 671mike
    • May 2012
    • 8
    mine was tell i stuffed it at somewere over 50mph it hit the water so hard it broke the battery tray loose and cracked the hull were the stringer was glued to the battery tray
    • Steve McGinley
      BMW Master Technician
      • Nov 2011
      • 52
      Wow, really!!?? I guess I probably shouldnt put that off any longer. Have you reinforced it since that mishap?
      • 671mike
        • May 2012
        • 8
        No I had it looked at and the repair man told me it be cheaper to get new one and carbon fiber it up before it hits the water. I will just put some epoxy on the cracks and foam the nose and run it tell get the new one done but I need to say this was a very hard crash at full speed and it did hit the bottom (6 feet of water wow)
        • jfraleyjr
          • Feb 2011
          • 18
          What is the part number for the cable you bought? I sent an email to OSE a few days ago and the reply stated they don't sell a cable for the Impulse because it is an odd size? Any info you can give me would be a big help!
          Originally posted by Steve McGinley View Post
          Okay so I broke the stock driveshaft after upgrading the motor and esc and prop. I have a question regarding the OSE upgraded HD driveshaft if anyone who has installed one in their impulse I could use some advice. I removed the teflon sleeve and have the etti coupler. I noticed that when I have the cable installed and the prop on the shaft I go to tighten up the supplied bullet nut and it doesnt even come close to the prop before bottoming out on the shaft. I received a regular nut, non nylock and the bullet nut. I tried installing the regular supplied nut and that tightens up all the way to the prop of course but I thought the bullet nut should be the only thing holding the prop on. I have the drive dog as far back as it will go but still the nut is too far away. Do I need to cut the shaft?
          • 671mike
            • May 2012
            • 8
            Product ID: ose-cable-impulse31-HD
            OSE Impulse HD Cable
            In Stock: 0
            OSE heavy duty flex cable (Requires etti-a034 coupler) assembly. This is for customers with heavily modified ProBoat Impulse 31 boats that are using 4074 and 4082 motors. Made with thicker gauge .187" Cable with 3/16" prop shaft and bullet nut. The cable we use is over 20% thicker than the stock ProBoat cable. This is cut and ready to install in your boat (requires etti-a034 coupler).
            No soldering or cutting required!
            NOTE: This will NOT fit a Stock Impulse without the following additions. Requires ett-a034 5mm to .187 Coupler and removal of stock proboat Teflon liner.
            This can also be used in any other boat requiring a .187 cable that measures approx 8 3/8" (212mm) from tip to tip.
            • Steve McGinley
              • Nov 2011
              • 52
              They are out of stock right now, put yourself on the product watch list so you're notified when its back in stock. MAKE SURE you also buy the etti coupler, you will have to remove the Teflon driveshaft sleeve in order for the cable to fit also. I cut my leopard motor shaft because the cable is too long but after that it fit perfectly. VERY happy with it and I haven't broken a shaft since. Mike has given you the product details, you can find it in the OSE shop under the hardware section then goto driveshaft cables.....you will find it in there.
