pro boat inpulse newbie question.....
  • stuey4
    • May 2012
    • 9
    hey everyone! I ordered my new impulse 31 that should be here tommorrow, just wondering what is the best prop size for this boat? i wil be running 5000mah 20c lipos. is this a decent battery choice for this boat? this will be my first rc boat!
  • JimClark
    • 5913
    look in the RTR Impulse section loads of info there
    Billy Graham
    • roadrashracing
      • 1630
      I would get batteries with a higher c rating, I run 25c and a little more prop draws a lot of current. Don't run batteries down to low, 4-5 min is what you will get for run time.
      • nokiaprinter
        • Jan 2012
        • 16
        try 42x55 or m445 make sure you upgrade the connectors to 5.5mm or above thou
        • BERTBORDEN
          • May 2012
          • 1
          Should I change the connectors on the batteries and the motor/esc or just the motor/esc?
          • Stephavee
            I like cool things!
            • 240
            x2 on that! i run a m445 and love it...i have the stock motor connectors but run all 5.5s on my bats. also re-do the water cooling so that the esc is the first to get the cooling water...they need to be cooler than the motors do!...have fun this will make a great "first" boat....and down the rabbit hole you go!
            " Do you really need anouther boat "
            YEP!
            • d.a.v.e
              • 230
              Both should be done if your thinking of that big of a prop. I also swap out the stock tubing for a larger diamiator tube that allows more water to get though. This seems to be good for reducing temps 5-10 degrees depending on water temps.
              • Stephavee
                I like cool things!
                • 240
                http://forums.offshoreelectrics.com/...mping-problems
                YEP!
