upgrades
  • 100 mph jet boat
    • Apr 2012
    • 121
    upgrades
    Hi guy's... I just ordered me a impulse 31 should be here next week.
    But in the mean time i would like to order some of the needed upgrades.
    so far from all my reading i should upgrade.
    5.5mm bullets
    flex cable
    collet / coupler
    trim tabs adj.
    prop x645, 42x55 grim racer, 45x55
    can anyone help me out with links or part #
    and is there anything else that i need to do????
  • roadrashracing
    • 1630
    I would just upgrade the bullets and prop, I never had a problem with anything else.
    • 100 mph jet boat
      • Apr 2012
      • 121
      That sound good to me
      What prop you running?
      • stadiumyamaha
        • 1371
        the 42x55 may work but the others are way to much prop for stock setup. That or bring a fire extinguisher.
        • roadrashracing
          • 1630
          I run the 42x55
          • 100 mph jet boat
            • Apr 2012
            • 121
            Thanks guys
            bullets, 42x55, adj tabs, 4 x 5000 40c 2s
            What size prop comes on the 31 .?????
            • stadiumyamaha
              • 1371
              Another easy upgrade is the run 4s2p (two 4s parallel). Double the run time and lowers amp pull considerably. Plus the impulse has plenty of room to fit high mah 4s batts in it.
              • 100 mph jet boat
                • Apr 2012
                • 121
                im with ya, my next set of batterys will be 4s. there out of stock
                • stadiumyamaha
                  • 1371
                  Try the sky lipos. I've had great luck with them. Better than the gens in my opinion.
