How do I remove the stock Teflon tube???
Installing OSE Upgraded flex cable........
Probably a 1.5 or 2mm. Go to your LHS and get a set of allen drivers. Standard "L" shaped allens wear quickly and easily strip.
Steven Vaccaro
Originally posted by TAMonti View PostThanks!!
I'm guessing Steven is correct. The set screw is MUCH smaller than a 2mm or even a 1.5mm. (Which I already tried)
I hope I'm correct.
If not I have about 1000 or more worth of cables out in the market that we have been using the wrong driver on.
Another words i can assure you that the oc6dmm drive dog takes a .050 driver.
The larger drive dog, oc6dm takes a 5/64 driver. I will add that info to the drive dog info.
Also I've never had good luck with the smaller L shaped allen wrenches with small grub screws. they usually just strip the screw. The larger stuff they would just fine on.Steven Vaccaro
