Whats your thoughts.
  • G-UNIT
    • 949
    I have a 1390kv motor,and down the road I'm thinking of putting it in my impulse with a 6s
    set up and a upgraded esc with a good size prop, not sure what yet but I know this is a high torque motor that can run 6s.
    what are some of your thoughts on this setup, I think it should be intresting. its a 12xl.
  • G-UNIT
    • 949
    Anybody??
    • G-UNIT
      • 949
      Ok, 1390 kv 12xl on 6s with a x645 prop and hit 54.5 mph and it handled very good only problem is I'm runing hot on the motor. 165-170 and thats with the water going into the motor first. the esc is at about 110 and the batterys are at 95, can't quite understand it, looks like plenty of water coming out, and even enlarged the inlet to the water jacket but left the outlet the same, should I enlarge it also? and just try and flow more water around the motor insted of restricting it before it leaves as I was thinking that it would have a chance for it to cool insted of just flowing around and out with out picking up any heat.
      • Diesel6401
        Memento Vivere
        • 4203
        - Could be a esc timing issue. Which esc are you using and what is the timing set at?
        - Could be to much prop for the 2 pole motor. Feigao's are also rather ineffecient.
        * 165-170 is bad territory, motors will start to de-mag around that temp.
        - Diesel's Youtube
        - Diesel's Fleet
        • G-UNIT
          • 949
          I have changed the timing a couple of times but no change in temps, can't remember what its set at right now and I'll get back on that.
          What do you feel the timing should be set to? I had it set high and lower but no change.
          I an useing a turnagey 120 esc.
          never heard anything bad about feigaos and i've run that same prop on a 1500 blackjack motor with no problems, I am also going to check over the cooling system again,
          but any othe suggestion anyone has will be helpfull. thanks.
          • eboat
            • Aug 2007
            • 693
            Can you try a smaller prop ? (yes it will be slower) or even an X445 or M445
            Sounds like the motor is just working too hard and heating up (you weakest link)
            • G-UNIT
              • 949
              Ran the m445 from my ul-1 and still high temps.
              heck I'll put on a x642 and see if that runs cooler, it's the smallest prop I got.
              I know it will be slower but maybe it will run cooler and then I'll work up from there.
              I picked this motor being told that its a 6s motor and also a higher torque motor, like I mentioned the esc and batterys are at good temps so I'll try a even lower timing and a smaller prop and see what happens.
              • Diesel6401
                Memento Vivere
                • 4203
                The Feigaos time has come and past (jmho) especially with the new and more effcient 4 pole leopard and leopard clones hitting the market at a amazing price. Shortly the feigaos will be phased out (once again jmho).
                They like timing at 7.5 on the hobbywing esc's. Propping is key on a 2pole motor. If overproped even slighty the amp spike (and temps) skyrocket. That PB1500 is a beast of a motor and 6pole plus better made (imho), not so picky with the prop selection and more forgiving. I def think you have to much prop on that motor. Try the x642 or a prather 220. Less dia more pitch.
                - Diesel's Youtube
                - Diesel's Fleet
                • G-UNIT
                  • 949
                  Ok thanks, i'll set the timeing as you say and run the x642 which is s/b/dt and see what happens, thanks for your input and I'll run it this sunday and post the results here. again thank you.
                  if all else fails i'll run the bj 1500kv in it that I'm running in the ul-1 right now untill can get another motor, I got the feigo because they have them at my LHS.
                  • G-UNIT
                    • 949
                    Ok I changed the timing to 7.5 and ran a x642 prop and the temps droped just abit, but still to high for comfort, down to 150 on the motor so i'll drop the timing to the next lower mark or even to 0 degrees and see what happens.
                    NO MORE feigoes for me.
                    my LHS also stocks ammo motors, how do these run?
                    I guess I'll just have to get a pay pal acct.
                    • Diesel6401
                      Memento Vivere
                      • 4203
                      I wouldn't lower the timing. It's y wind motor, y winds don't respond well to low timing. Every Feigao i ever had always ran hot. Try a x442 or a prather 215. 7.5 was always the timing that worked well for me.
                      Ammo brand inrunners are mostly 2 pole as well I believe, but are more effcient. Switch over to the Leopards, you will be very happy!
                      - Diesel's Youtube
                      - Diesel's Fleet
                      • G-UNIT
                        • 949
                        Ok ,next time I'm at the lhs I'll pick up a x442 and see what happens.
                        The water here is starting to cool down so maybe that will healp also.
                        When $$ is avaible I'll get a leopard, what on do you reccommend for 6s.
                        • Darin Jordan
                          • 8332
                          Feigao motors are only 2-pole motors... They are going to run hotter, especially if you have too much timing in them.
                          That being said, David Newland runs them in a lot of boats and seems to have the setups down... So I can be done.
                          Remember, also, that there is more to making a prop selection than just pitch. You can have two props with the same pitch (42x55 vs 45x55, for example), but the smaller prop will load the motor LESS. Diameter adds load. Perhaps stepping down to a 42mm will have a noticeable improvement.
                          Darin E. Jordan - Renton, WA
                          • G-UNIT
                            • 949
                            I'll give it a shot, you guys never steered me wrong yet.
                            THANKS.
                            • Darin Jordan
                              • 8332
                              You can also unload the prop you have by raising the strut a bit to get some of the blade out of the water, or back-cutting the blade slightly to reduce the blade area near the hub. De-Tonguing it some would also help... The 1.6 pitch ration on the X645 is more than I'd recommend for a 2-pole setup. They just don't have the torque that a 4 or 6 pole does.
                              The X642 would be a good start. Don't give up on it if at first is seems to be a bunch slower. It's not as simple as just swapping props. As I just mentioned above, there are other factors as well. Where is your strut location currently??
