any solid motor upgrades for the impulse 31 yet??
  • Darin Jordan
    • 9446
    Originally posted by LarrysDrifter View Post
    I see the Thunder Power motor is sensored. Will it run without a sensor wire, or does one need to use a car/truck esc with it? Darin, I know you've been boating for a lot longer than me, but ive never seen a sensored marine esc. What esc are you using?
    I run mine sensor-less with a Hydra 240.
    Darin E. Jordan - Renton, WA
    • rwhitfield
      • Aug 2011
      • 21
      Which motor do you own, and what ESC do you pair with it? I am confused on the options for this one on the OSE site. I am looking for 50mph ish running 4s2p running a M445 prop. Any help would be great, as th motor specs have me all worked up!
      • Jpope
        • Feb 2011
        • 30
        I currently run mine stock and get 33.7mph out of it. Scroll up and read Darins first post about the 2100kv motor. That's what I have ordered to drop in along with a sea king 180esc. That should push this boat into the 50s no problem. I'll post my results soon as I get my new stuff put in. If you upgrade yours quicker post your results.
        • rwhitfield
          • Aug 2011
          • 21
          So... I am looking at the Leopard 2150kv 2Y out on OSE.... but can someone with some knowledge clue me in as to what the 2D, 2Y, 3Y designations mean on the spec / model numbers on some of these motors??? Is this just part of the model numbers, or is this a technical variable I need to make consideration of? The Keda motor looks interesting, but I think the Leopard has better operating specs.
          Any help or confirmation on this would be appreciated!
          • G1ST
            • Dec 2010
            • 351
            I am running a Tacon 4074 - 2150kv with a Hydra 240 on 4S.
            Is the X645 still the prop of choice?
            What kind of speeds can I expect?
            Thanks
            Greg
            • petej
              • Jun 2010
              • 163
              Which water jacket do you use with either the THPM18A1900 or the THPM18A2100?
              Pete
              Motley Crew, Impulse 31, Zonda Cat, Genesis, Aqua Rider tug, E-Revo Brushless, Slash4x4
