pro boat impulse new power system suggestions
  • Piranhafreak
    • Jul 2011
    • 25
    Hey all im working on a new setup on my impulse as stock was just way to slow i was looking at x445 prop with the leopard 4082 1450kv motor running on 8s how does that sound or does anyone have a better suggestions
  • steveo
    • 1454
    maybe a 1250 kv would be good as well how fast do you want to go?
    • Piranhafreak
      • Jul 2011
      • 25
      as fast as i can make it go for about 400 bucks motor and esc
      • roadrashracing
        • 1462
        what are you running for batteries?
        I found this on another thread, update the speed control and go nuts.
        Impulse 31
        Stock – 32mph on 4S-45C
        Stock – 47mph on 6S-25C
        Stock – 47mph on 6S-50C
        1.9” Prop – 48mph on 6S-25C (Yes, we know you told us not to try this prop with this setup, and as you warned, we fried the ESC on this setup)
        • Piranhafreak
          • Jul 2011
          • 25
          havent decided on batts yes once i figure on motor and esc then i will decide i know i will be running either 2 3s or 4s in series so 6s or 8s i would like to see 60mph at least. The only problem i have with going 8s is it really limits my choice of esc
          right now i think this will be my setup and it changes minute by minute
          1 hobbywing 180amp esc
          1 castle 10amp bec
          1 Leopard 4082 Motor 1450kv
          2 ZIPPY Flightmax 5000mAh 3S1P 40C
          1 Octura x645 prop
          • Mtwinste
            • Jul 2011
            • 135
            That setup is VERY similar to mine and won't get you guaranteed 60. I was 54-56 yesterday and running pretty dang dry on a finished and balanced prop.
            • martin
              • 2869
              On the specs given it calcs out to 57mph so very close to actual runs done. You may have a better chance of 60+ mph with the 4082/2y 1600kv as this setup in the Spartans is into mid 60s mph. I simply wouldnt try the 180amp esc on 8s either youll get smoke, Stick to 6s on thar esc.
              • Piranhafreak
                • Jul 2011
                • 25
                If i were to go 8s i wouldnt use that esc still undecided
                still thinking on mabey even selling the impulse 31 and getting a gasser
                • svtfrank
                  • Aug 2011
                  • 40
                  Seems to me like it's gonna start to get pretty heavy with that much battery in it. Got my Leopard 4074 on the way and a few props to test! Can't wait to see what she'll do with double the HP and a little more prop!!!!
                  • rwhitfield
                    • Aug 2011
                    • 19
                    Martin-
                    How did you determine "with the specs given it calcs out to 57mph" if I may ask? I am specing out a Leopard 4074 2150kv 2Y on a Seaking 180 ESC on 4s2p lipo. I was planning to try a x445 or M445 prop. I was guessing that at 3.7*4*2150 I would turn 31,820 rpms.... but have no clue how you can derive a "spec speed" bassed on that!
                    Do tell!!
                    And if anyone else wants to tell me that this motor / esc combo is a bad idea then speak up now before I hit the BUY button!!
                    • TheShaughnessy
                      • 1419
                      go to the top of the page. there is a tab for the speed calculator, should be able to figure it out from there. also multiply 31820 by .8 to factor in 80% motor efficiency
                      • c_michael_72
                        • Oct 2011
                        • 184
                        63mph
                        I've hit 63mph reliably with the following setup on my Impulse 31:
                        Leopard 4082 2200kv
                        Turnigy 180 ESC
                        Prather s225
                        Two 3 cell's in series
                        Steven's upgraded flex shaft (a must)
                        • rwhitfield
                          • Aug 2011
                          • 19
                          c_michael_72-
                          Couple of quick questions:
                          1) is that the "2Y" 2200 kv Leopard motor? If you (or anyone) can explain the technical variable on that one I would appreciate it, as the 2D, 3D, etc stuff is what I am uninformed about while making potential selections.
                          2) I would guess that with 4s2p on your set up the Impulse might top out around 50?
                          3) What kind of run time do you get on your 6s1p batts??? Guessing 6-7 mins tops?
                          4) Would you mind posting the link to the OSE "upgraded flex shaft"?
                          Thanks for any help in advance,
                          RW
                          4)
                          • c_michael_72
                            • Oct 2011
                            • 184
                            1) The 4082 2200KV only comes in a Y wind. I'm not up on the differences between the wind configurations, Steven may be able to help you with that.
                            2) Your guess sounds about right, but I never ran that configuration so I don't know.
                            3) I run 2 5000mAh batts and get 4ish minutes, but I have a long lake and do mostly WOT.
                            4) http://www.offshoreelectrics.com/pro...able-impulse31
                            • rwhitfield
                              • Aug 2011
                              • 19
                              Much appreciated c_michael_72!
