Ran tonight with x445 prop and 3S2s gens ace 5300mah 45c and burned up something. Motor or ESC not sure. Motor was way hotter than esc. Oh well I didn't really care I wanted to upgrade it anyways. Recorded 44.4mph on this setup before she blew and she was running pretty loose at that time.
28.7mph on 2S
what are you saying? 3S2s??Originally posted by Mtwinste View PostRan tonight with x445 prop and 3S2s gens ace 5300mah 45c and burned up something. Motor or ESC not sure. Motor was way hotter than esc. Oh well I didn't really care I wanted to upgrade it anyways. Recorded 44.4mph on this setup before she blew and she was running pretty loose at that time.
are you running two 3s packs in series or parallel??.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
this system is ment for 4s power the way you ran it was 6sOriginally posted by Mtwinste View PostSeries. Stock electronics. Stock wiring. Series.
to much voltage with that prop possibly burnt up your esc.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Mtwinste, you need to be more clear when you are posting. 3S2S. what does that mean? Does that mean 2x 3s packs which means 6s total? Or do you mean you ran a 3s pack and a 2s pack in series for 5s total?
good to hear about the motor and esc doing ok!
try a different prop on the stock setup while running 4s
you will like it...NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
Ran the x445 on two thunder power 2S 65C 6600mah in series. 43.4mph. Ran the batteries dead and the motor batteries esc everything was hot and even a little smoke came out from inside the hull!!!! Let it cool some and tried another pair of 2S packs and she was thermalled and wouldnt go over idle. New ESC and motor are on the way.
this is a solid setup from ProboatOriginally posted by Mtwinste View PostRan the x445 on two thunder power 2S 65C 6600mah in series. 43.4mph. Ran the batteries dead and the motor batteries esc everything was hot and even a little smoke came out from inside the hull!!!! Let it cool some and tried another pair of 2S packs and she was thermalled and wouldnt go over idle. New ESC and motor are on the way.
sounds like your looking to see smoke on every run
