Impulse 31 totalled.......
  • GOGEICOGO
    • Aug 2011
    • 25
    So after talking with proboat today they said the reason why i was having problems with the boat cutting out was due to the batteries i was using. Apparently 40c is to low of a discharge rate. they said i need to use 50C. So i went down to my lhs and bought some new lipos (thunderpower). With in 30 seconds of my run the boat took off by itself and crashed into a rock. TOTALLED. the boat sank as far as im concerned. I called proboat back and they said they cant send me out a new boat. Pretty ticked off right now. $400 for the boat plus $250 for lipos down the drain.
    • 9438
    I bet it was fast. Seriously that is no fun at all. Sorry to hear of this loss.
    • Rumdog
      • 6453
      Wait, Didn't you have 20c lipos?
      Did you EVER range test it after the initial problem you had or did you just throw it back in the pond?
      • Rumdog
        • 6453
        Also, did you ever put new batteries in your transmitter?
        • GOGEICOGO
          • Aug 2011
          • 25
          yes i did range test and it was fine. i have 20c lipos and 40c lipos. And i did put new batteries in the radio. the boat crashed with 2-2s 5000 50c lipos that i had just purchased from my lhs.
          • Rumdog
            • 6453
            So, what could the issue have been. Doesnt make much sense here. Checked fine on land. 40c was well more than enough. Any pics of the carnage? Nothing got wet? Ever?
            • Basstronics
              • 2303
              Ouch that sucks!
              Did you get the boat back or is it on the bottom with Davey Jones?
              • JPriami
                N4FOX
                • 1675
                That blows. Sorry to hear about that. But seriously recovery of anything salvageable is in your best interest.
                • GOGEICOGO
                  • Aug 2011
                  • 25
                  It beats me man. I think it was the esc and receiver. It wasn't the radio because i used the one from my geico and the same problem happened. no pics. the boat is gone it sank. from what i saw the boat basically exploded when it hit the rock. such a nice boat to.
                  • Rumdog
                    • 6453
                    how did it hit a rock then sink? Arent rocks usually on shore?
                    Did steering go out also?
                    • GOGEICOGO
                      • Aug 2011
                      • 25
                      yes the steering went out. the boat hit a small island thats about 200 yards out from where i was running it. but the rock the i hit was like a wall. and i no the drop off out there is pretty deep.
                      • LarrysDrifter
                        Big Booty Daddy
                        • 3278
                        That kind of loss will make a guy re-think rc boats as a hobby. I know its more frustrating than land rc vehicles.
                        • iamandrew
                          • 574
                          I really doubt your 40C batteries were the issue here....
                            • 4297
                            Sorry hear what happen to your boat.
                            But if it was me i would have to go snorkeling this week for it.
                            Was it salt water or fresh water ?
                            • Make-a-Wake
                              FE Rules!
                              • 5554
                              The 40c/50c story just doesnt make sense................that boat can run on 20c 5000 batts if a person wanted to, the batts would get a bit warm but it wouldnt make a difference in it going wild as aopposed to 40 or 50c. Why would they tell you it runs on 50c, cuz thats just plain false. It was a radio issue i'm bettin'.
                              Here are Proboats "specs" directly from their site:
                              Length: 31 in (787mm)
                              Beam: 9 in (229mm)
                              Motor Size: 1800Kv brushless water-cooled
                              Radio: Pro Boat 2.4GHz pistol grip transmitter/Spektrum MR200 receiver
                              Speed Control: 60-amp brushless water-cooled
                              Hull Material: Fiberglass composite
                              Prop Size: 1.6 in x 2.5 in
                              Hull Type: Fiberglass Deep-V
                              Battery: 2-7.2V Ni-MH sub-C or 7.4 Li-Po 20C+ (not included)
                              Kit/RTR: RTR
                              Drive System: Flex shaft/direct
                              Minimum Age Recommendation: 14 years
