New Proboat Impulse 31" Deep Vee
  • Diesel6401
    Memento Vivere
    • 4391
    #91
    Darin i noticed at the 3:48 mark on the new "On the Horizon" video the coupler isn't the normal PB coupler we are use to, but is a staight (set screw) coupler. Is this wire drive?
    - Diesel's Youtube
    - Diesel's Fleet
    • Darin Jordan
      • 9446
      #92
      No... it has a .150" flex cable...
      Darin E. Jordan - Renton, WA
      • Diesel6401
        Memento Vivere
        • 4391
        #93
        Thanks, im getting ancy on this boat... Im ready for her
        - Diesel's Youtube
        - Diesel's Fleet
        • lonneyb
          • Feb 2011
          • 83
          #94
          Originally posted by wparsons View Post
          Depends on what kinds of packs you're running.
          For 2s1p, I just run normal 5.5mm bullets negative on esc to negative on one battery, positive on esc to positive on other battery, and the remaining two together.
          If you have two 4s packs and want them in parallel, you'll need a y adapter on each ESC wire.
          If you have 2s packs and want to combine them into 4s2p you'll need the two y adapters as well as plugging the packs together like I do.
          That would be what i would want to do i have 2 Turnigy nano-tech 6000mah 4S 25~50C Lipo Pack...do u have a link to the Y adaptor or a diagram to make one>?
          Thanx in advance
          Spektrum Radios
          Proboat "Impulse" 31 Deep-V
          Proboat "Mystic" (On the list!)
          • SpektrumAndrew
            • Jul 2011
            • 13
            #95
            I've got one on back order at my LHS can't wait to get it.
            • JackBlack26
              • May 2007
              • 904
              #96
              Is the stuffing tube chambered because it does not have a stinger? Boat looks great. I just hope the lid isn't thin plastic like the Geico.
              • wparsons
                • 461
                #97
                Nope, but having it chambered gives you MUCH more room to adjust it. You typically can't get as much adjustment out of a stinger either.
                Light travels faster than sound, so people may appear to be bright until you hear them speak.
                  Originally posted by lonneyb View Post
                  Also would you use a special connector for series and/or parallel?...Thanx again
                  Yes, typically home made but, can be purchased from OSE.
                    Thanx in advance
                    One Y should have one female at bottom and two males at the top, the other needs to be opposite. One male at bottom & 2 female at top.
                    Plug each pack into the pairs of Y wires and then you have a pair left for input to esc.
                    Make sure you connect positive to positive and negative to negative or .
                    • dmwilson09
                      • 100
                      #100
                      Would 2 - 2S SPC 4700 mAh 25 Lipo packs be more than enough for this boat. Also, can the electronics on this boat handle 6S?
                      • dmwilson09
                        • 100
                        #101
                        It measures about 29.5" down the keel... 31" to the overhang.
                        The hull has a unique spray rail design that should help keep it from submarining most of the time, as well...
                        Initial speeds are typical of the power system... ProBoat took all their boats out and did some radar testing, using bone stock, out of the box boats with stock, un-prepped ProBoat props and here are the notes they sent me for this boat:
                        Impulse 31
                        Stock – 32mph on 4S-45C
                        Stock – 47mph on 6S-25C
                        Stock – 47mph on 6S-50C
                        1.9” Prop – 48mph on 6S-25C (Yes, we know you told us not to try this prop with this setup, and as you warned, we fried the ESC on this setup)
                        So, I'd expect about 40 or so with the right prop on 4S and obviously much faster with more cells. And WAY faster with more motor!
                        What prop would be recommended to get the boat to 40 plus on 4S?
                        • wparsons
                          • 461
                          #102
                          Not sure about the prop, but if you're going to push it on 4s I would get 40C packs to be safe.
                          • v-spec
                            • Jun 2009
                            • 1046
                            #103
                            It'll do 40+ with an x445
                            • slow-at-rc
                              WANNA RIDE BIKES :)
                              • 133
                              #104
                              Mine is in the 40's or real close to it with a x445 with two Thunder power 40 c packs
                              Brappp
                              • cvlex
                                • 19
                                #105
                                Two 2S5000mAh packs or one 4S5000mAh pack for this boat?
                                Although I already have six ProTek 2S5000mAh40C packs for my Shockwave 26 BL and Miss Geico 29, it might be easier to charge one 4S pack than two 2S packs.
                                Any tips or recommendations are all welcome.
                                Thanks in advance,
                                cvlex
                                AQ Mini Rio (BL upgraded), Reef Racer 2(BL upgraded), PB Impulse 31, Miss Geico 29BL w. OSE upgrade flex cable and x642, ShockWave 26BL w. JETI Advance 50 Navy and x435, Tenshock Mini Eco, Starship (AKA Mini-Y)
