Stability Problem Quastion....
  • p.swiggs
    • 86
    r 2 water pick ups necesary? or would i be fine with the one on the rudder and turn the tubing into a "Y" for the motor then esc? is the stock water cooling ok?
    • LiPo Power
      DJI Drone Advanced Pilot
      • 3186
      One cooling line is fine. I is just me.... Mind you that 2 of them are even better to keep temps down but Fastech and BJ stock setup is running very cool on one line so no worries. When it comes to Y for cooling it is not my best idea becouse water will allways go the easier way so it wont be devided equally.
      Robert
      Canada
      • p.swiggs
        • 86
        so would that be the same for T cooling? if it is i could see why you chose to pick ups so its divided equally..
        • p.swiggs
          • 86
          If the trim tabs were bend down,wouldnt that make the nose of the boat stay down too?i always hear of the nose getting pretty close of submerging.
          • LiPo Power
            • 3186
            ... trims down will make boat run wet, yes nose down but will decrease speed and it may increase load on your esc and motor wich means you may gain a little on your temps, make sure to check temps often.... You need to find the perfect balance....
            Canada
            • p.swiggs
              • 86
              ok i see this so the point of doing this is so the nose isnt always in the air and it gets on plane?
              • p.swiggs
                • 86
                I see that when the nose is down it will handle a bit better too right?
                • LiPo Power
                  • 3186
                  It will but will also slow down and worm up a liitle higher. You need to play arround with it. Find the perfect balance between plane and in the water for the optimal performance that you will like the most...
                  Canada
                  • p.swiggs
                    • 86
                    ahhh i got it.thanks
