How should I fix this Flex Shaft?
  • Visual Perfection
    • 316
    Had my Fastech out last time and it quit out on the water, motor revved but no movement.
    After getting it in I found the flex shaft was the culprit
    Here is what is should look like all one solid piece
    here is how it is, the end piece just turns freely and can be pulled off as shown in the picture.
    How do I re-attach it, or do I need to get a replacement?
    Thanks
    The Speeders *PB SW 26 BL *PB Formula FASTech
    The Cruiser *CBM Marlin Cruiser
    The Pool Toys *Proboat Mini-C (x2)
  • dana
    • Mar 2010
    • 3660
    if it was soldered in you can heat with torch and resolder.
    • Visual Perfection
      • 316
      Well I don't have a torch, but will have a new soldering iron (100w) arriving in the next couple days so I will see if I can do something with that.
      • dont slow down
        • Feb 2011
        • 125
        This just happened to me about 30 min ago. So it's just soldered?
        Real men have shafts.
        • Visual Perfection
          • 316
          Ya I fixed mine by just re-soldering it on..unfortunately when putting it back in the motor was a little mis aligned and I forced it too hard and wrecked the other end..go figure
          So a new drive shaft I will need..just can't get one now as I am not spending any more money on my boats since we just found out we have a baby on the way so priorities have changed... So my fastech is now dry docked for a while lol
          • SirBudman32
            • Aug 2011
            • 701
            Is that a 4mm flex with the square drive on the end? and if so how long is it I may have one.
            Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
            • G-UNIT
              • 971
              I use green loctite, bearing retainer, and it works great on the stub shaft, never lost a prop yet,
              • Visual Perfection
                • 316
                I'm not sure what size it is, it's the stock shaft for a proboat formula fastech. Maybe someone can chime in that knows.
                • SirBudman32
                  • Aug 2011
                  • 701
                  I have a piece that is 9 3/4 inchs long that I dont need. If it will work, could send to you.
