Having a few problems with my proboat formula fastech
  • jakedanger
    • Feb 2011
    • 4
    I have a Proboat Formula fastech, with (2) Venom 5000mah 40C LiPo's and a sharpened & balanced Octura x642 prop. The radio, ESC and motor are stock.
    Problems
    1. After I plug the ESC into the programming card (which seems to accept the data) and back into the reciever I have to unplug the batteries and plug them back in to get the boat to work.
    2. After charging my batteries and programming the ESC and plugging everything in, I go to run my boat and sometimes it runs with no problems, but then other times power to the motor cuts in and out, but the steering never loses power, like i have a short somewhere. I just dont know if its in the motor, reciever, transmitter or what!!?? Please Help
  • dana
    • Mar 2010
    • 3660
    Check solder connections
    • Make-a-Wake
      FE Rules!
      • 6057
      Yep, check your connections. a 642 is a big prop for that motor, the wires could be getting very hot and some unsoldering may have occurred.
      • BHChieftain
        Fast Electric Addict
        • 2051
        Problems
        Regarding #1, I believe that is typical behavior for this ESC. I've used a couple of proboat ESCs and I frequently need to completely remove power (turning the on/off switch isn't enough) to reset.
        I have also had problems with connectors de-soldering when using x642 prop. X442 also works really well on this boat.
        Chief
        • jakedanger
          • Feb 2011
          • 4
          @ dana and make-a-wake
          Thanks but the soldering was not the problem
          @BHChieftain
          So by disconnecting the batteries and connecting them back, is the esc still good with the data i set the card at and do i have to reprogram the esc everytime i use the boat even if i dont want to change any data or does it stay at the last setting i put it at
          • jakedanger
            • Feb 2011
            • 4
            • jakedanger
              • Feb 2011
              • 4
              • dont slow down
                • Feb 2011
                • 125
                You don't have to program it every time.
                Real men have shafts.
                • BHChieftain
                  • 2051
                  Right, you don't need to reprogram the ESC after power is removed.
                  On your other problem-- how are the temps? Anything getting really hot? You also might want to try a different set of batteries-- maybe you have a cell that is hitting LVC. Try setting the LVC cutoff to low.
                  Chief
