ProBoat Formula Fastech Brushless Deep V Q.
  • CumminsTurboDiesel
    • Feb 2011
    • 15
    Brand new to this site had a couple of people rec. it to me im glad they did but my question is on my Formula Fastech Brushless i am running everything bone stock running gear and batteries have run it about 5 times now at the lake in smooth clam waters but i have having the problem of my flexshaft at the motor side leaking water and its all greesed properly just wondering what i need to do to stop the leak or slow it down? THANKS for any help!!
  • Diesel6401
    Memento Vivere
    • 4391
    I would assume you mean water coming up threw the stuffing tube (brass tube)? It's common, some guys place heat shrink over the end or a small sponge under the tube I use a small piece of fuel tubing (the cooling tubing on your boat). Works for me...
    - Diesel's Youtube
    - Diesel's Fleet
      • Feb 2011
      • 15
      man thanks alot for the reply there and the picture were im talking about is the shaft from the prop that goes thru the hull up to the motor and right there under the radio box its throws some water out i just dont want it to ruin anything in there i am totally new to the rc boats this is my first one so ill be asking alot of questions on here haha thanks for the help!
      • Diesel6401
        Memento Vivere
        • 4391
        I think I know what you mean now. If their is a very small gap around the stuffing tubing in the inside I'm sure you could remove the radio box and epoxy around were the stuffing tube enters the hull. You could also place a piece of shrink wrap on the strut & tube if possible Both may help. I don't own this boat, just throwing you ideas on similar problems i have had.
        - Diesel's Youtube
        - Diesel's Fleet
          • Feb 2011
          • 15
          I will proably try one of those ideas thanks alot ill get all this figured out before long....my next question on this boat is i dont plan on doin a lipo swap yet as bad as i want to but what are some other options on makin this thing run even better? i have been seeing alot of suggestions on the x642 balanced and sharp props for this boat does anyone think i would see a diff. in the boat? do i need to change anything? or is it a bolt on kinda deal?
          • sanyijr
            • 377
            x642
            The X642 makes a pretty good difference. It's much quieter, faster top end and faster out of the hole. Seems to be overall much smoother. Bolt on.... But if you are on NICD or NIMH, the move to LIPO is a bigger upgrade.....
            • the savy fluxer
              • 83
              i agree, thats exastly what i did, with the x642 and a turnigy aquastar 120 amp esc with 2 5000mah 2s lipos and it made twice the difference.
              now the boat is a riot on the lake it goes as fast as most of the big boats.
                • Feb 2011
                • 15
                I want to do the swap so bad i dono were to start or how to do it and dont wanna spend a crazy amount of money any pointers?
                • the savy fluxer
                  • 83
                  order yourself a turnigy lipo charger, 4 5000 mah 30c 2s 7.2 v lipos and a turnighy aquastar 120 amp esc with programmer. and or coarse get the x642 prop from your local hobbystore or from here.
                  thats it then you have a rockin boat thats great for the beginner. Thats how i started the stock motor will do just fine with this setup, tried, tested and true.
                  • Diesel6401
                    Memento Vivere
                    • 4391
                    Lipo's are 7.4v, 7.2 is nimh/nicad. The turingy Aquastar car be purchased here at OSE http://www.offshoreelectrics.com/pro...=hef-sword-120. I agree lipo's would be the best upgrade for you. The best ones I have found are avail in the usa warehouse and are the 5k 40c's. These things are great... The best charger that I have found for beginners, and the charger I was recommended when I was new to lipos is this Hyperion http://rclipos.com/HP-EOS0606i.htm. It should come with xh balance board which the turnigy lipo's use... Excellent charger and easy to begin on.
                    - Diesel's Youtube
                    - Diesel's Fleet
                      • Feb 2011
                      • 15
                      wow all this stuff sounds crazy! haha i hope i will be able to figure it all out is it a pricey swap? i am prolly asking to many questions on here lol
                      • the savy fluxer
                        • 83
                        i think it cost me 250 or a bit less
                        • Diesel6401
                          Memento Vivere
                          • 4391
                          Nope just batteries and a charger. What charger do you have now. Does it say lipo on it? Lipo's from HK are actually cheaper then most nimh lol. Crazy!
                          You will need the PB Programming card so you can enable the low voltage cutoff. http://www.horizonhobby.com/Products...ProdID=PRB3311
                          - Diesel's Youtube
                          - Diesel's Fleet
                            • Feb 2011
                            • 15
                            The charger i have now is the dynamite twin peak chargein my 2 rec. batts. for my boat so i could get started will that work? i wish there was a hobby shop close to me i could drop my boat off at and tell them to do the swap and make it fast haha!.... cause i am new to this stuff and still learning about it all
                            • Diesel6401
                              Memento Vivere
                              • 4391
                              Is this the charger you have: http://www.dynamiterc.com/Products/D...ProdID=DYN4033
                              If so this will not work for Lipo's and you will also need to upgrade your charger. The best way to do it is to learn. I love just working on them, it's not about just the runtime for me. It's building something up and then finally seeing it in action. It can put a big smile on your face or piss you off lol. I just enjoy every aspect of it....
                              A few guys have used this charger with good results: http://www.hobbyhot.com/gt-power-dua...-1-pr-905.html
                              I myself have not used it, but some guys who have do like it. For that charger and some Turnigy packs I listed before, for $100 (not including shipping) you can jump into lipo's...
                              Take your time and learn about everything. It will safe you time and money. Also read up on lipos before you start, best thing you can do is prepare yourself and learn. When in doubt do a search for your question on this forum, if you don't find your answer then ask a question. I have found this is by far the best forum for boating. JMO of course.
                              - Diesel's Youtube
                              - Diesel's Fleet
