Waterproofing tips
  • BHChieftain
    Fast Electric Addict
    • 2051
    Waterproofing tips
    1) To seal up the antennae hole, use those waxy earplugs-- two of them work great
    2) Glad press and seal wrap is a great alternative to a balloon to waterproof a receiver-- I had a boat underwater for 3+ hours and the unit stayed dry and functional.
    3) My nimh packs got water in them-- I split open the plastic wrap to let them air out, and used the press and seal wrap plus a bit of electrical tape to reseal them. Nice benefit is you can take off the wrap to let them dry if they get wet again.
    -Chief
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    -Chief
    Fastech 3 hurs under water !!!!!! Why so long? This must be the record for this boat sitting under water..
    I hope your hutch was taped well at all the painfull to tape corners...
    This is what I had on my boat to seal antenna opening, see picture.
    Friends allways complain about the time I had to take to tape my boat. Fastech hatch has few areas you need to take time to do good job sealing it....
    Canada
    • BHChieftain
      • 2051
      The hatch was taped, but it did not keep the water out. It was COMPLETELY filled with water, and was just bobbing with the nose peeking up... it took 3 hours for the wind to blow her back to shore...
      But she is fine and still running great!
      -Chief
      • LiPo Power
        • 3678
        -Chief
        You can use WD-40 to spray your motor just in case. Works great and will push all the water out and protect.
        Canada
