Miss Elam hop ups
  • monojeff
    • Nov 2010
    • 2728
    Ok guys I gpsed my Elam today with a UL-1 motor and running it on 4s with a 443 fightercat aluminum prop it ran 46.5mph consistently and is very stable this is the setup I have been using for heat racing. I tape the first break off all the way from the canards to the tunnel floor and tape up the turbine opening to help stop it from lifting. I know there is more in this boat with this motor still tweaking and tuning and trying a few more things. Temps so far seam very mild so definitely room for improvement.
    OSE GIFTING ELF
    HAPPY HOLIDAYS!!
    • monojeff
      • Nov 2010
      • 2728
      I hit 50.6mph today and handling was pretty good a little flighty but not bad with some tweaking think it could be easily manageable.
      UL-1 motor
      Used a 645prop that was cut down to 43mm and cupped by Mark Sholund (props4u.com)
      I rounded the tips sorta like a 42x55 prop because last time out I hit something but it seamed to help the prop a bit.
      Also tried a 42x55 prop but got the same 46.5mph as before.
      I also managed to burn up my motor the run after I think I kinked a water line or something.
      So will be testing out the stock motor to see what I can get out of it.
      OSE GIFTING ELF
      HAPPY HOLIDAYS!!
      • Scamp73
        • 105
        UL-1 motor
        I see you had been running the Elam. Did you ever make make a replacement decal set for this boat?
        • monojeff
          • Nov 2010
          • 2728
          No I never got around to it.
          I have been busy with other projects.
          If you need some decals send me a pm.
          OSE GIFTING ELF
          HAPPY HOLIDAYS!!
          • Scamp73
            • 105
            I am getting consistant 50mph out of my Elam using the UL-1 set up on 4s. Still trying to find the right amout of weight to add to the front to keep her from blowing over but I can usually avoid it by adding a slight amount of rudder when she looks like its gonna go over.
