Help with prop shaft on miss elam (help me understand why)
  • rctoyznhobby
    • Jul 2011
    • 80
    I went and ran my miss elam for the first time yesterday and i put the boat in the water started moving forward as the boat started to pick up speed within 20feet it has that low start off as it was ready to burst take off the prop shaft bent. I checked the prop it it ballanced it had a brass shim in it to fit i had the right drive dog on it. What can i do to stop this is there a upgrade to a thicker shaft and flex drive and prop shaft strut?
    If they do make an upgrade any part numbers and maker would help
    thank you
    heres what it looked like
    [ATTACH=CONFIG]55251[/ATTACH]
  • Camaroracer
    • May 2011
    • 22
    I am having the same problem with my Miss Llumar Nitro Hydro and will be watching for some help.
    Also i need the part number for the rudder pushrod
    Picture of my damage
    • billf1973
      • Feb 2011
      • 170
      I had the same problem with my Elam. If you read Darin's thread he explains why this happens. My flex shaft, stuffing tube, and prop shaft all were bent. Also, I reinforced the radio area inside the boat.
      JAE 45 FE, DF Vortex 24, PB Mystic, Aeromarine Sprint Cat 42, Aeromarine Sprint Cat 36
