spacer
  • Notch-R
    • Dec 2021
    • 17
    spacer
    how do i fill the gap when running after market props?
    ul-19, min-dom, Veles29
  • Alfa Spirit
    • 2183
    Use a nylstop screw, not this purple bullet.
    • Notch-R
      • Dec 2021
      • 17
      i use the screw then the bullet on the stock prop.the aftermarket has a shorter hub.20220114_091858[365].jpg
      • Notch-R
        • Dec 2021
        • 17
        why do the pictures post sidways?
        • NativePaul
          Greased Weasel
          • 2770
          Use a piece of fuel/water cooling tube as a spacer.
          • Alfa Spirit
            • 2183
            You can reduce the flexshaft lenght.
            • Notch-R
              • Dec 2021
              • 17
              then the stock style prop won't work
              • Notch-R
                • Dec 2021
                • 17
                • Notch-R
                  • Dec 2021
                  • 17
                  i need the spacer shown above
                  • koen
                    • Mar 2020
                    • 367
                    you can fill the gap with peek rings(it's a kind of teflon)it gives also no problem with the balance of the propshaft (tfl sells them)
                    • Notch-R
                      • Dec 2021
                      • 17
                      i found one here at the ose store
