New Stilleto Owner
  • CDN Racer
    • Feb 2012
    • 13
    New Stilleto Owner
    I just picked up a new Stilleto. I don't race my boats, except the better half and her Miss Gieco and my Spartan LOL (with all the mods)
    Would like some help on best all round props to use, two or three blade. Also what Lipo's best match for this boat but I guess that depends on the prop too. I now have SS P215's I just got from OSE on the other two boats, talk about professional balancing and thinning (Thanks OSE)!!
    Thanks Guys
    Gerald from Canada
    Mine...Traxxas Spartan & Proboat Stilleto
    Her's ... Miss Geico
    And just got my Aquacraft Silver Revolt 30 !!
  • CHIEFY_44
    • Nov 2010
    • 254
    i had one of these and i used 4 cell 5000mh batteries and the prop i used was a p220 shapened and balanced this worked for me
    Socal Fe member, miss gieco castle 1515 1y t-180, blackjack29 stock,insane FE30 p sport castle 1515 1y t-180, insane FE30 p spec ul-1 motor t-120, insane 34"mono neu 1521 1.5d t-180
    • CDN Racer
      • Feb 2012
      • 13
      Thanks Chiefy I just ordered the last S&B - S.S. P220 OSE had. Hard to find 4 Cell 5000mh here in canada would using two 2S 5000MH 25C Lipos work the same. I am still having a hard time understanding all the lingo on batteries.
      • jasoncyclone
        • Jun 2011
        • 495
        You can use 2 2S 5000MA. I would get 40C or higher if you can!!!! You can see the difference!
        Miss Geico CC1515 2200kv T180 2S2S- Twin Genesis with 2 2700kv 2 T180's 4S2P- Stiletto with 2030kv T120 4S1P-DF33 4082 1600kv T180 6S2P- and lots of gassers!
        • CHIEFY_44
          • Nov 2010
          • 254
          I agree with Jason the higher C rated cells the better, I started with 40/90 nano tech and they were ok but when I switched to thunder power 65c cells there was a big difference.
          Read the race prep post that Darin Jordan wrote and do everything he suggests as they do make a big difference also makes maintance easier.
          • CDN Racer
            • Feb 2012
            • 13
            Thank you Gentleman
            I have been reading Darins race prep post and have learned a lot. In regard to the batteries I see Thunder Power 5300MAH, 2S, 7.4V G6 Pro Race
            65C with Deans part #THP53002SP65C would this be the one you are talking about ?
            Thanks Again
            Gerald
              • 7512
              Several of us run 5800 30C Turnigys with great success in our tunnels...with 2030Kv motors and m445 props. Whereabouts in Ont. are you located?
              • CDN Racer
                • Feb 2012
                • 13
                IN Brampton, played with smaller boats at the summer place in Peterborough now have the big toys LOL. Have a Spartan and this. Other half has a Miss Gieco.
                  • 7512
                  Should join us in Cambridge, May 6th for our next club race....
                  • jasoncyclone
                    • Jun 2011
                    • 495
                    I would not run the deans connectors. You should use 5.5 or 6.0 bullets. They have a much better connection. The deans connectors will get very hot and will limit the power to the motor...
                    Originally posted by CDN Racer View Post
                    Thank you Gentleman
                    Thanks Again
                    Gerald
                    • CHIEFY_44
                      • Nov 2010
                      • 254
                      You could use them but as Jason says you would need to change all connectors to atleast 5.5mm ones including the motor to esc ones, personally I would opt for the 5000 4s 65c rated ones as it is easier to move the cells to get ur cog correct, I found with these I placed them level with the esc shelf and that just about was perfect for the cog. Another mod I done was to remove the steering cables and replace them with 4-40 rod its a pain but can be done and well worth doing it, I also changed the cover for the center with a flat piece of clear perspex this helps with taping it down and gives the cables/rods more room.
                      Hope this helps you out.
