Turnigy 120 ESC Programing..
  • ibo24
    • Sep 2011
    • 34
    Have got ma turnigy program card now,can anyone advise on some decent settings for the turnigy 120a esc useing stock motor and prop,Iam not a racer or a basher just yet,
    eg,Lipo cut off or slow down so I can retreive the boat and any other susgestions,
    ibo..
    Iam who Iam, except this and we will get along fine..
  • Griff
    • Jul 2011
    • 69
    have you got the card with the 12 settings? if so you only have 4 programmable settings for the 120
    setting 1 running mode, 1=forward only 2=forward backward
    setting 2 lipo cells, 1=auto calculate 2= 2cells 3= 3cells 4= 4cells 5=5cells 6=6cells
    setting 3 low voltage, 1= auto 2=2.8v/cell 3=3.0v/cell 4=3.3v/cell 5=3.4v/cell
    setting 4 timing, 1= 0.00*, 2=3.75*, 3=7.5*, 4=11.25*, 5=15.00*, 6=18.74*, 7=22.5*, 8=26.25*,
    the settings that are on the front of the card do not actually relate to the marine esc took a while for me to find this out.
    the timing I run may be a little on the high side although my temps when running 15* are ok., you may want to run at 11.25*
    set mine on these settings and all seemed to be ok
    running mode=1, forward only
    lipos = 4, 4cells
    low voltage = 4, 3.2v/cell
    timing = 5, 15.00* maybe drop that to 4, 11.25*
    this is what mines set at not saying this is the right settings just what I use
    Tom
    • ibo24
      • Sep 2011
      • 34
      Ok Tom cheers,
      will try your settings then and take it from there,instructions are a bit double dutch to me,
      thanks
      ibo
      • jamespl
        • 748
        I went from 15 timing to 11 and it didn't seem to make any difference to the speed but temps were lower. I use the seaking card and it tells you the boat settings on the front. So at the mo I'm running the same esc settings as Griff and all ok.
        • ibo24
          • Sep 2011
          • 34
          I have one of these
          Turnigy ESC Program Card Marine, K-Force, EZ-Run V1/V2 and the only setting I can use are,1 forward/Reverse and and lipo cut off,this cannot be right surely ?? running a Turnigy 120a esc..
