Stiletto Battery and Charger Help
  • geradmg513
    • May 2011
    • 5
    I recently decided to get into boats and bought a Pro Boat Stiletto and I am a newbie. These are the recommended batteries
    • DYN5351D 7.4V 3200mAh 25C Li-Po
    with Deans Connector
    • DYN5352D 7.4V 4200mAh 25C Li-Po
    • DYN5360D 7.4V 5300mAh 25C Li-Po
    • DYN5361D 7.4V 6000mAh 25C Li-Po
    What would be a good choice for the battery as well as a charger. I don't want something super expensive but also something that works
  • LiPo Power
    DJI Drone Advanced Pilot
    • 3678
    The larger mAh the longer your running time will be so go for 6000mAh.
    I would get 1 4S 5000mAh or larger LiPo with the higher the better C rating, let's say 40C or up.
    Charger that works:
    http://www.hobbyking.com/hobbyking/s...dProduct=11060
    You will need power supply:
    http://www.hobbyking.com/hobbyking/s...idProduct=9205
    Cheers
    Canada
    • JimClark
      • 5913
      get rid of the Deans
      Billy Graham
      • geradmg513
        • May 2011
        • 5
        It looks like that charger is out of stock. Any others? Would these batteries be ok?
        http://www.hobbyking.com/hobbyking/s...dProduct=10285
        Also how hard is it to change the connector? The boat comes with deans but the batteries have bullet.
        Sorry but I'm new to all this. I had a blade cx 3 helicopter before this and it was all very simple
        • JimClark
          • 5913
          just need a good 40 watt soldering iron
          Billy Graham
          • LiPo Power
            • 3678
            Most of the chargers on HK website are ok for what you need to do...
            Canada
