Stiletto ESC cooling question
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    Is it just mine, or is the ESC cooling plate, have a lot of resistance to pressure?
    I took my ESC out to install 5.5mm bullets, then I attached one hose to the cooling and blew through the tube with a lot of difficulty. I tried it on the other nipple, and the same resistance in the other direction. so much resistance, that I see the silicone tube swell as the air passes through the ESC. Before I get questions about kinks in the line or another device attached, it is just the ESC and one hose. nothing else involved.
    I'm sure glad I never ran it yet.
    Any ideas please?
    Thanks!
  • Darin Jordan
    • 8332
    I took my ESC out to install 5.5mm bullets, then I attached one hose to the cooling and blew through the tube with a lot of difficulty. I tried it on the other nipple, and the same resistance in the other direction. so much resistance, that I see the silicone tube swell as the air passes through the ESC. Before I get questions about links in the line or another device attached, it is just the ESC and one hose. nothing else involved.
    Any ideas please?
    Thanks!
    I'll have to check mine tonight and compare it to the 45A ESCs...
    Darin E. Jordan - Renton, WA
    • Diegoboy
      Administrator
      • Mar 2007
      • 7247
      Please do, thank you Darin
        • 7277
        You are not supposed to install 5.5mm bullets on the cooling lines!
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          I had to re-read my post!
          • ron1950
            • 3024
            my 45a in the mg seems to be very free as i blow the water out of it after i run it to stop the water from drooling out on the seats of the truck have to try the stiletto now......ok both are the same as far as i can tell....
            • JimClark
              • 5902
              I used one in my 1/10th scale and did not check it for flow but water came through just fine and everythign was plenty cool guess I should check the 45 and 60's i have also just for kicks.
              Or you can just send it to me if you are too concerned
              Billy Graham
