leopard motor
  • xxxrems38xxx
    • Mar 2010
    • 172
    leopard motor
    hi,
    i'm in order the 2000kv leopard for my hydro boat, but do you think it's good in my futur stiletto? thanks
  • Diegoboy
    • Mar 2007
    • 7443
    I'm going to guess "too big"
    • Diegoboy
      • Mar 2007
      • 7443
      the 4074 2000kv motor is 40mm diameter
      the ul-1 2030kv motor is 36mm diameter
      4074 = 4mm thicker diameter
      the 4074 motor is 74mm long
      the ul-1 motor is 56mm long
      4074 is 18mm longer
      The UL-1 motor barely fits under the outboard cover, the leopard 4074 will not fit under there.
      If you run it without the cover, it will fit!
      English to French translation
      le moteur 4074 2000kv est 40mm de diamètre
      l'ul-1 2030kv moteur est de 36mm de diamètre
      4074 = 4 mm de diamètre plus épais
      le moteur 4074 est 74mm de long
      l'ul-1 du moteur est 56mm de long
      4074 est de 18mm de plus
      L'UL-1 moteur s'adapte à peine sous le capot moteur hors-bord, le léopard 4074 ne rentre pas là-dessous.
      Si on le lance sans le couvercle, il sera en forme!
      ListenRead phonetically
      • xxxrems38xxx
        • Mar 2010
        • 172
        Hihihihi thanks diegoboy for your translation!!!!!
        when i receive the beast i make a test with it without cover! by the cons the 2030kv of aquacraft makes me think that there should be a little too powerful or am I wrong? anyway it does is that tests that say!
        • F1 madness
          • Feb 2010
          • 788
          you could use the 3660 range of leopard motors they should fit and have a large range of kvs aswell.also have their own water jackets which fit a treat
          http://s577.photobucket.com/albums/s...79/F1%20boats/
          Daz from sunny England
          • Diegoboy
            • Mar 2007
            • 7443
            I haven't been able to find a pic of those 3660 motor wires. If the motor wires come out the back of the can, it will NOT fit in this OB. If they come out the side like the 4074's, it should fit.
            • F1 madness
              • Feb 2010
              • 788
              yep im sure they come out of the side of the can the same as the 4074
              • ron1950
                • 3082
                i put a ul-1 motor in the stiletto and it just barley fits under the fiberglass motor cover....
                • Diegoboy
                  • Mar 2007
                  • 7443
                  ...because of the wires exiting the can at the back. You should have the room for the added 4mm can length if the wires exit the side as stated above.
                  • GP73
                    • 546
                    I just got Leopard 4074 2150Kv for another boat and it doesn't fit under the cowl of the Stiletto.
                    You might be able to make it fit if you cut the cowl like Darin did, I'm not sure if the bolt pattern will work though, I haven't checked.
                    • Diegoboy
                      • Mar 2007
                      • 7443
                      there was no debate about the 4074 fitting, because it won't. we're discussing the leopard 3660 series.
                      • GP73
                        • 546
                        Ops, didn't read the whole thread properly...
                        • Diegoboy
                          • Mar 2007
                          • 7443
                          No problem. It DID start out about the 4074, but evolved into the 3660.
                          • F1 madness
                            • Feb 2010
                            • 788
                            My fault LOL,just sugesting a motor that would fit under the cowl
                            • Darin Jordan
                              • 9446
                              Hey Guys... I put one of these in my Stiletto this past weekend to go after the NAMBA 2-Lap record with.
                              Didn't get it on the water long enough to tune it, but it looked REALLY fast for the lap I was able to complete! Need to do some tuning to keep the boat on the water at these speeds.
                              Here's what it looks like in the boat... Had to cutup the canopy a bit, but it sure looks cool once it's in there....
                              I wouldn't recommend THIS hot of a motor for anything other than shorter runs, and only with some decent batteries. I had a 50C ThunderPower ProPower 5200mah pack, and a Hydra 240ESC...
                              Darin E. Jordan - Renton, WA
