Crossing the brand name line
  • Darin Jordan
    • 9446
    Originally posted by Diegoboy View Post
    I am! Woo Hoo!
    PB motor = 53mm long
    UL-1 motor = 56mm long
    I hope that adds at least a little back to the missing torque.
    When you pull these motors apart, you'll find that the stator and rotors are exactly the same length... only the cans are different.
    I've burned them all up and have torn them all down.
    Darin E. Jordan - Renton, WA
    • Doug Smock
      • 5359
      Darin my brother. Ya got to learn not to burn. lol J/K
      Danny I'm glad to see have a tunnel. Your going to have a blast with it next year!!
      Doug
      MODEL BOAT RACER
      IMPBA President
      IMPBA 19887L CD
      NAMBA 1169
      • Darin Jordan
        • 9446
        I burn... so you don't have to!
        • Doug Smock
          • 5359
          Thank you sir!
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Rumdog
            • 6667
            hippie!
            • Darin Jordan
              • 9446
              This statement is true for the PB BJ26/MG motors vs the UL-1...
              The Stiletto motor is actually shorter inside by about 1/8". 1885KV, but less mass yet, so torque suffers.
              • Diegoboy
                • Mar 2007
                • 7443
                Doug
                Doug, I also got a cobra tunnel in custom blue/yellow coming. I picked up an OS lower unit from my LHS for that. I'll be needing all the tunnel gurus advice for that one...
                • Diegoboy
                  • Mar 2007
                  • 7443
                  The stiletto will be my spec, and the cobra willbe my P
                  • hazegry
                    • Jun 2010
                    • 842
                    danny your outboard is done
                    • kevink
                      • Jun 2010
                      • 47
                      Just got back from running with the UL-1 motor. With Grim 42x55, I barely had it up to full throttle. Temps were great after 3 minutes. 88 degrees on the motor and esc. Too windy today to be comfortable at full throttle.
                      • Diegoboy
                        • Mar 2007
                        • 7443
                        nice report, even on a 42mm prop. SWEET
                          • 9481
                          How do you think it did vs the stock motor?
                          • kevink
                            • Jun 2010
                            • 47
                            Ul1 vs stock
                            When I got the stiletto, I was seriously disappointed with the lack of speed. Now with the ul1 motor, I am timid to hit full throttle. There is now a serious increase in speed. So much that I will probably go down to a smaller prop. Expected the temps to increase. Temps went down a bit but that is probably due to the decrease in water temps. The last time I ran the stock motor the water temps were around 98 degrees. Today's water temps were around 80.
                            Today's run was with the stock esc but installed 5.5mm plugs and hyper performance flex. The stock cable unwound because it was in contact with the outboard housing at the motor end. Corrected by opening the hole just enough to clear the flex shaft. Check the alignment as Darin suggested. Also, if you use the ul1 motor the esc rev limiter with no load prevents the motor from operating out of water.
                              • 9481
                              Right on man!
                              sounds like a great direction with this hull
                              • Diegoboy
                                • Mar 2007
                                • 7443
                                Awesome, my UL-1 motor should be here Monday afternoon, I can't wait!
